Results 1 to 8 of 8
Thread: vs v8 engine temp
    vs maloo
    Mar 2010
    Default vs v8 engine temp
    Hey there commodore fans I have a v8 5l could someone out there tell me what temp on your dash gauge shows when at running temp. What's the highest the engine temp should reach on the gauge? I know different termostats have different temps I have a standard trident thermostat.
    VR SS
    Sep 2010
    1995 vs v8 ute
    Oct 2010
    hoppers crossing (victoria)
    mine got above half way once... when i towed another car it never went over half way.
    VS HSV Clubsport
    Jan 2009
    Wellington, NZ
    dirt drifter's Avatar
    dirt drifter is offline white trash hillbillie
    VS 5L M5 VS 6L M6
    Apr 2009
    massive hole in the ground
    1/4 or 1/8 on mine depending on ambient temp and if im up it or not
    Quote Originally Posted by UFO View Post
    worked v8 + supercharger + dogbox = panty moistening equipment.
    4 banger turbos with bov's will just cry when they hear it, because they can never have it.
    Quote Originally Posted by GRPABT1 View Post
    Avoid cluey police
    Demonica's Avatar
    Demonica is offline Mrs Wraith
    VS clubby
    Mar 2010
    SE Qld
    My clubby sits slightly over the 1/4 mark and thats as high as I've seen it go
    VS 5 Litre BT1
    Jul 2006
    Mine generally sits on the second line from the bottom however lately has been moving up to the third line on occassions. It has also started using a bit of coolant as well though recently so need to fund the cause !!
    vr statesman 5.0 + vs exec s2 auto
    Mar 2006
    central coast, nsw
    my 5 liter vr stato sits on 1/4 on temp gauge . when i first got it , used to go up to 1/2 on a warm day. but after i put a 180 degree ( fahrenheit ) thermostat in and also tightened the belt for the water pump and alternator its ok now.
LinkBacks (?)
  1. 10-07-2011, 11:37 PM
  1. Engine Temp
    By ss-1 in forum General
    Last Post: 23-10-2009, 09:11 PM
  2. VS-VT Engine Temp
    By ORIXVywags in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-10-2009, 10:42 PM
  3. gauges oil temp and engine temp
    By vzon20s in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 24-11-2008, 05:31 PM
  4. engine temp
    By gungazza in forum VL Holden Commodore (1986 - 1988)
    Last Post: 08-10-2007, 06:36 PM
  5. engine temp
    By vnbelina in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-02-2006, 09:26 PM
