Results 1 to 4 of 4
Thread: Code 47 - Crank Angle Reference Signal
    vs berlina s2
    Feb 2009
    Default Code 47 - Crank Angle Reference Signal
    What does this mean in plain and simple english lol
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    It means that for some reason or other, the signal that normally goes from the crank angle sensor to the DFI module telling it to fire a sparkplug has failed - it may have failed once or 100 times but it will log a fault despite it being only a milli-second..
    Unless you are having stalling problems, just clear the code by removing the battery for 30 secs (or pull engine fuse) and this will clear the code. Then drive car as normal and check codes in a few days. If the code reappears it possibly is a sign that the CAS is on it's way out. Good Luck.
    GTP 85's Avatar
    GTP 85 is offline 291 hp @ the wheels
    VS track car & VS SSenator
    Aug 2006
    Adelaide, near the bay
    I had this problem, replacing the cas didnt fix it. So if you're in the same boat it could possibly be a break in the wire somewhere. I re routed a new wire from the ecu to the dfi, fixed it.
    Hit me up with some reputation points if i've helped you out! (Star in the bottom left!) Cheers!
    GT Performance RUF 231- NA 3.8L- 13.30 @ 103 Mph... So far... Cam, compression and revs! MY CAR>> http://forums.justcommodores.com.au/...tml#post471410
    Daily VR SS: http://forums.justcommodores.com.au/...ite-vr-ss.html
    nathanVY's Avatar
    nathanVY is offline need boost...
    03 VY Calais, 99 VT Equipe
    Dec 2009
    Geelong, VIC
    I had this code, it was my CAS. The car stalled once and wouldn't start for AGES. Then it randomly started and didn't do it again for weeks, then I got it replaced lol.
  1. Code 47....18x Reference Signal Missing
    By mal62 in forum Electrical Wiring / Questions
    Last Post: 19-09-2011, 10:34 PM
  2. Code 47 - 18x Reference Signal Missing
    By Kurtp in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-02-2010, 01:46 PM
  3. Cam angle sensor (no signal)
    By Chris F in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 29-07-2009, 12:35 AM
  4. Crank angle reference signal (no signal) code 47
    By gc-tec in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-10-2004, 10:29 PM
  5. Code 47..18X Reference Signal Missing
    By muney in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-08-2004, 05:32 PM
