i have a vr calis manual
it starts and idols but when you go to put you foot down it wants to stall
have replaced fule pump and everything is fine with that what else could it be
cheers
sounds like the problem i had, months to find and lots of money, have you checked your plugs? mine rooted coil pack... if you have done all the fuel, then it is usually the ignition somwhere... give your iac stepper motor a good cleen too i found they can cause these problems too..
