Results 1 to 5 of 5
Thread: Powersteering pump pressure plate
    vs berlina s2
    Feb 2009
    Default Powersteering pump pressure plate
    Ive got the back housing off and the big o-ring out but i cant seem to get the next back preesure plate off. ive done a search but othing really of help. i dont wanna go off like a shot out of a gun and damage something
    The1's Avatar
    The1 is offline A Memcal a Day Keeps..
    VS V6 Berlina Auto Series 1
    Jan 2005
    Toowoomba QLD
    just tap the front shaft to push it in, it'l pop out then, then you need to take the circlip off the rotor, dont loose all the little wings, then you can pull the whole shaft out so you can then get at the front seal to replace it, just remember which way the pressure plate goes back on, if you dont have those 2 holes lined back up right you'll have no pressure as it's blocked off.
    vs berlina s2
    Feb 2009
    ok ive done another search. i have one front seal. 2 big o rings and 2 o rings. one goes under the high pressure line. but the other one?
    vs berlina s2
    Feb 2009
    ive searched the hole pump. i cant find a second o-ring and it looks too big to fit on the high pressure line hose. its the same size o-ring that goes under the high pressure valve
    The1's Avatar
    Jan 2005
    Toowoomba QLD
    you have to undo the bolt at the back of the pump where the high pressure line goes, there's a spring it sits in there.
LinkBacks (?)
  1. Vy powersteering pump
    By Timmos in forum VY Holden Commodore (2002 - 2004)
    Last Post: 17-08-2009, 03:18 PM
  2. [SA] 2nd Hand CLutch Plate + Pressure Plate For Sale Suit VN / VP / VR
    By social in forum Parts And Other Items For Sale
    Last Post: 29-04-2009, 12:10 AM
  3. Powersteering pump stuffed?
    By Apoc in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-08-2006, 06:10 PM
  4. powersteering pump
    By anfsvl in forum Parts And Other Items For Sale
    Last Post: 16-04-2006, 01:24 AM
