Results 1 to 4 of 4
Thread: vr auto problem.
    toyota lexcen - vr.
    Jan 2009
    victor harbor
    Default vr auto problem.
    a few months ago i punched a hole in my orginal block. so i replaced the engine. all was well for the test drive and then my gear box started slipping.
    it turns out one of the hoses was leaking, so i topped it up. this didnt fix the problem. it wouldnt change til 3500 revs every, and it slowly got worse til it changed at 5500 revs. so i assumed i cooked the tranny.
    so i hammered it til the engine started making noises, and changed the engine and orginal box with another engine and gearbox that i hadnt pulled apart. i though beauty, the problem would be solved. turns out i was wrong. i then replaced the computer, and its still changing at 5500 revs.
    i am lost for what to do, and i really dont want to take it off the road as it was a present and a first car.
    Quote Originally Posted by Chilly View Post
    My GF tried to call mine Molly....I raged. Still deciding on what I'll call it
    toyota lexcen - vr.
    Jan 2009
    victor harbor
    just had a thought. im using the same throttle body. would the TPS cause these symptoms?
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Could well be....usual cause is the TPS. Hope the auto is still OK!!
    toyota lexcen - vr.
    Jan 2009
    victor harbor
    tps was the problem. bastard thing!
LinkBacks (?)
  1. 16-02-2011, 04:34 PM
  1. Problem with VZ auto in VX
    By sleepa in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-08-2010, 05:57 PM
  2. Vn auto problem
    By GeorgeM in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-02-2010, 11:23 AM
  3. vs ss auto problem
    By tinyinass in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-08-2009, 05:37 PM
  4. problem with auto
    By KingCoMMoDore in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-02-2006, 08:34 PM
  5. problem with VR V6 auto
    By krizko in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-03-2005, 09:25 PM
