Results 1 to 6 of 6
Thread: abs brakes
    vn vr vs commodore
    Nov 2010
    bundaberg qld
    Default abs brakes
    can u fit vs abs brakes into a vr
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Only if you want to spend more than the car is worth - apart from new hubs you need the ABS sensing mechanism and the pump plus all the wiring etc etc plus an engineers report. Much cheaper to buy a VR with it on already in my opinion.
    hsv91ss's Avatar
    hsv91ss is offline Holden4eva!
    VS Commodore SII
    Jun 2005
    Central Coast
    As said it wouldn't be worth it though the ABS Unit used in the VS is a better unit then what was used in the VR models were abs equipped.
    RX25SE's Avatar
    RX25SE is offline Real cars are steel cars.
    vsII acclaim wagon
    Jan 2009
    Quote Originally Posted by raymon woodley View Post
    Yes.
    But you wouldn't.
    As above, sell and buy a VS with abs.
    VR SS
    Dec 2010
    Quote Originally Posted by hsv91ss View Post
    If the ABS unit in the VS is better than the ABS unit in the VR can you swap them over? ie. fit the VS unit into a VR. What is it that makes the VS a better ABS unit?
    db_notso's Avatar
    db_notso is offline diagnostic technician...
    vt v6, mods(susp brakesetc...)
    Oct 2010
    sunshine coast, qld
    no computer (abs module) uses differnt "wave signal" from sensors would be far too costly
    there is a reaction time for the module and a thought process within it with advances in electronics one model variant is enough to outdo another
  1. Vx S2 Brakes
    By Ray De Man in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-12-2009, 06:07 PM
  2. brakes?
    By target101 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 09-09-2009, 06:06 PM
  3. Brakes Vt-Vn
    By madsav in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-09-2009, 11:56 AM
  4. Drum brakes to Disc brakes conversion
    By sheepz89 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 25-09-2008, 09:34 AM
  5. Brakes..?!
    By My Car Pwns in forum VL Holden Commodore (1986 - 1988)
    Last Post: 15-05-2006, 05:31 PM
