Results 1 to 8 of 8
Thread: Boot lid sitting high on one corner
    Cammed mafless VS Calais 5-speed.
    Dec 2008
    Default Boot lid sitting high on one corner
    Sitting high.
    This is the other corner, sitting properly.
    I can't for the life of me work out why one corner would sit higher than the other. The old boot lid sat fine but for some reason this one doesnt. Does anyone have an ideas?
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    I cannot give you a proper answer, but what I'd do is get inside the boot with a socket that will loosen the hinge bolts, then get someone (who you trust!) to shut the lid - then loosen the hinge bolts and have the person outside press down on the high corner to hopefully align the lid better and then tighten....then tighten.
    Good Luck.
    1997 Vs Commodore Executive
    Oct 2010
    Bundaberg
    Dec 2008
    VS_Pete_1's Avatar
    VS_Pete_1 is offline Donating Member
    VE II SV6 MY12 Sportwagon
    Dec 2007
    Quote Originally Posted by hako View Post
    Good Luck.
    I did that to one of my cars worked a treat.
    "Success is the ability to go from one failure to another with no loss of enthusiasm" Sir Winston Churchill.
    My VS II Berlina Wagon
    MY12 II SV6 Sportwagon
    VP calais, VJ valiant, BG5 legacy
    Jan 2008
    New Plymouth, New Zealand
    Its because the hinge, or where the hinge bolts up to the inside of the lid is bent.
    Take the lid off and hammer it straight.
    Quote Originally Posted by QuickVRII95 View Post
    Elaborate, For All Of Us... How The Hell Is A Commodore A Friggin 4-Stroke...???
    Where Are You Getting Your Facts From...???
    You All ARE Wrong About A Commodore Being A 4 Stroke Engine... Or Any Car For A Matter Of Fact...
    A V6 CAN'T Run On ONLY 1 Cylinder... IT'S A 24 STROKE ENGINE... 4 CYCLES Per Cylinder... "Basically Three V-Twins Together
    jetboy's Avatar
    jetboy is offline You learn til u die
    VT exec
    Feb 2010
    Gold Coast QLD
    Simple , the boot lid is too far forward prob only a coupla mm , whats happening is where it raises up on the inside of the boot , just back from where it seals , is hitting on the seal causing it to sit up . Open the boot and undo the mounting bolts an pull it back a bit , an hey presto your problem will be solved
    VR_Acclaim is offline Banned
    Vr acclaim
    Jun 2010
    Is this the same with aftermarket bars where u can see where they bolt up under the boot
  1. VS Corner Sub Box
    By dmo89 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-01-2012, 05:37 PM
  2. Replies: 4
    Last Post: 03-01-2011, 07:59 PM
  3. Boot corner boxes.
    By Stretchomatic in forum Car Audio
    Last Post: 12-03-2008, 04:01 PM
  4. Corner boot sub box
    By Stretchomatic in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-10-2007, 09:46 AM
  5. HSV/Calais/Berlina Boot Mould Not Sitting Properly! Help Needed
    By finnbe in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-09-2007, 03:16 PM
