Results 1 to 4 of 4
Thread: Immobilized issues
    VR_Acclaim is offline Banned
    Vr acclaim
    Jun 2010
    Default Immobilized issues
    Ok so to turn my immobilizer off I gotta turn my key on and off 3 or more times and press the unlock buttons the same wats goin on? How can I fix it
    vs commodore
    Oct 2009
    Tamworth NSW
    Maybe the battery in the key fob is going flat,or there could be a problem with the BCM (Body Control Module).You can try disconnecting the negative battery terminal for a minute or two which should reset the BCM.High level BCM's can be reset by removing the fuel pump fuse for one second.The fuel pump fuse is located under the bonnet in the fuse box.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Could also be the key not making proper contact with the key reader which is that metal ring thing around the ignition keyhole - it must contact the metal lump above the key when you insert the key - when the two touch they basically shake hands and say "all OK". The 2 small screws in the fob/key must also be tight.
    If the key remote still unlocks the doors, the battery should be OK.
    Vr acclaim
    Jun 2010
    I'll try tightening the key my drivers side door won't lock by the button. It doesn't even try the rest will if u lock the drivers by the key...would thT just be the regulator
  1. Vt l67 issues
    By HARVZ-6 in forum Yella Terra
    Last Post: 25-10-2009, 05:16 PM
  2. VZ issues
    By sxcmonkey in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 22-03-2009, 02:21 PM
  3. 6 x 9 issues
    By speedracer006 in forum Car Audio
    Last Post: 29-11-2008, 09:49 AM
  4. VT issues
    By buzurk in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-05-2007, 01:17 AM
  5. VN tow bar issues
    By timmy_tam in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-02-2007, 10:30 PM
