Results 1 to 2 of 2
Thread: VS Alarm problems
    vp
    Aug 2010
    australia
    Default VS Alarm problems
    Hi, so i bought a VS series II acclaim a month ago. today i bought a new cd player, forgot about the alarm, i cut the wires off the current cd player that it had in and then the alarm went off, the unlock button on my key didn't turn it off, my dad opened the hood and said i needed a special key to turn the alarm off (which i never got from the dealer)
    i tried to re-plug the old cd player and no luck, the alarm does not go off when i turn the key on (and i can even drive) but as soon as it's off and the doors are open the alarm goes off. i can shut all the doors and actually lock the car (the alarm shuts up) however the locking doesn't lock the car like it used to anymore.
    We tried to take fuses out and we even cut 1 of the 2 wires on the alarm and no luck, removing battery just makes the alarm go on.
    right now car is in my driveway with the doors unlocked but the alarm on (it's not ringing) and now what's my options. tomorrow morning dad suggested i go to an auto electrician to get it sorted, anyone else have any ideas?
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    If you can, go back to the dealer. Failing that, if you want to keep the alarm in working condition go to an auto electrician. If you don't want to keep the alarm, locate the actual alarm horn and disable it by shoving an old sock in it to quiten it and then cut the wires to it so as it will stop when the battery runs down.
    The car should have a statutory warranty if you bought it from a dealer and that should cover the alarm. Good Luck.
  1. viper alarm problems
    By vr1962 in forum Electrical Wiring / Questions
    Last Post: 10-08-2009, 09:06 PM
  2. VX Equipe factory Alarm Problems
    By ScoHar in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-06-2009, 01:12 AM
  3. Alarm upgrade problems
    By jayderichards in forum Electrical Wiring / Questions
    Last Post: 24-03-2009, 05:18 PM
  4. Vx Ss Series 2 Alarm Problems
    By genIIIbandit in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-07-2006, 08:01 PM
  5. alarm problems with vp
    By craig murray in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-05-2004, 06:20 PM
