Hey evry1, since i have bought the VS i have had a problem wif the Front parker lights
If the parkers bulbs are instaled they stay on when lights a switched off...but they turn off when i turn it to parkers??? wtf
Any help would be appreaciated
Its a 97 VS berlina V6 ecotec
Id check the park lamps relay.It might be faulty.Just temporarily swap the park lamps relay over for one of the other relays that are the same as it, and see if the problem then goes away.
sure thing man, were is it excatlly lol
Is it wif the fuses under the dash or in the e-bay
Its the second relay from the passenger side of the fuse box under the steering column.Theres a relay for the rear window demister under there too,just try it in the park lamps one.Its the first relay on the passenger side of the fuse box and its the same type of relay.These relays are not the usual square type relays,these are smaller and are rectangle with a blue stripe.If you do find one is faulty,make sure the replacement has the same coloured stripe and the same amount of pins.There are some similar relays used on this vehicle but they have a different amount of pins and a gold stripe.They are not interchangeable with the blue stripe ones and vice versa.
