Results 1 to 5 of 5
Thread: Can I do this?
    85 VK Berlina
    Jun 2006
    Default Can I do this?
    Hi guys, I'm just wondering can I put a 5lt motor and trans (cable kickdown) out of a vp into a vs? I have the loom and computer out of the vp if that helps. Cheers.
    Red 1985 VK Berlina Commodore
    Dec 2009
    Quote Originally Posted by Gunns VC View Post
    You would need to check with your state regestration authority, you would need to consider the ADR's relevent ot the VR engine that the VP engine may not meet. For example exhaust emmission requirements. The engines may be the same with a differnet tune to achieve this, the VR ECU may be improved overt the VP to achieve this?
    RX25SE's Avatar
    RX25SE is offline Real cars are steel cars.
    vsII acclaim wagon
    Jan 2009
    Work out the costing carefully. There will be small items that will also need to be considered.
    May well work out cheaper and more effective to by a factory fitted VR V8.
    85 VK Berlina
    Jun 2006
    Ok sweet, if I was to just use the car for racing and burnout comps and not drive it on the road would it be an easy job?
    85 VK Berlina
    Jun 2006
    Any help much appreciated it's sort of urgent lol
