Results 1 to 12 of 12
Thread: Vr v6 showin systems of cas failure but not logging codes
    VR_Acclaim is offline Banned
    Vr acclaim
    Jun 2010
    Default Vr v6 showin systems of cas failure but not logging codes
    Ok so my vr broke down today and I got it goin after tryin to crank it over numerous time.. N letting it sit for 5 minutes on the way home it wouldn't rev past 2500 it just broke down till I payed off... It then stopped 3 hours later it cranks first time and rev freely WTF???
    RX25SE's Avatar
    RX25SE is offline Real cars are steel cars.
    vsII acclaim wagon
    Jan 2009
    If its breaking down under load (when you accelerate) and struggles to rev then this would normally be an ignition (high voltage side) fault.
    eg. Coils or leads.
    Vr acclaim
    Jun 2010
    RX25SE's Avatar
    vsII acclaim wagon
    Jan 2009
    Not great.
    How big can you make the gap before it won't jump?
    Have you tested a lead from each coil?
    Vr acclaim
    Jun 2010
    vx s pack II
    Jan 2010
    aLKIDA
    First of check for codes. Bridge pins 5&6.
    Check for spark with a spark plug tester.
    If there is no spark it could be the coils,DFI module,CAS,EFI relay. Also check the connection on the DFI module.
    You can check these parts if there in working order.
    It also could be the fuel pressure. Check pressure on the fuel rail. Fuel pump,fuel pressure regulator.
    Vr acclaim
    Jun 2010
    vs commodore
    Oct 2009
    Tamworth NSW
    vx s pack II
    Jan 2010
    aLKIDA
    Quote Originally Posted by Brett_jjj View Post
    Sometimes a faulty CAS wont set an error code.
    This is true. But there is a way to test the cas. You need a oscilloscope. To see the signal its producing.
    vx s pack II
    Jan 2010
    aLKIDA
    Quote Originally Posted by VR_Acclaim View Post
    No code and fuel pressure is good
    What reading did you get on the fuel pressure test at idle and full throttle.
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    That's what I thought the spark is only orange is that bad
    Sparks should always be a nice bright blue, so yeah orange = bad. Check your leads for excessive resistance then if ok maybe your coil packs are on the way out.
    Vr acclaim
    Jun 2010
    O just fogured press was good when fuel pissed out if the regulator when the hose was off
  1. engine warning light showin up.02 sensor??
    By Vt_vic in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-03-2009, 06:09 PM
  2. my account keeps logging out
    By quick308 in forum Site Feedback / Site Problems
    Last Post: 03-02-2009, 01:13 AM
  3. Logging Off
    By AussieHolden in forum Site Feedback / Site Problems
    Last Post: 26-01-2005, 08:47 PM
  4. Logging In To Download Section
    By VT1968 in forum Site Feedback / Site Problems
    Last Post: 15-02-2004, 09:50 AM
  5. Logging In Problems
    By fourstar82 in forum Site Feedback / Site Problems
    Last Post: 18-01-2004, 09:51 PM
