hey guys ive noticed a water leak in my 95 vs wagon which seems to look like its coming from the back of the engine near the transmission.i have no access to ramps or a hoist to get a good look were its coming from but thats the general area its leaking from.im losing about 1 litre of water every 3-4 days any suggestions on were its comming from? thanks
If it is coolant, might be a welch plug?
The aircon will condense moisture from the air as it cools it down, the water then runs out of drain tubes under the transmission. It will be clear. If the water leaking is green it will be coolant.
Rear main seal if it's ecotec.
See my thread.
nathans VY Calais - 'Calais 2.0' | VT Equipe | VS Calais **SOLD!**
