Results 1 to 11 of 11
Thread: Gilmer belt drive. Help please
    vp berlina(v6), vs statesman(v8)
    Dec 2008
    Default Gilmer belt drive. Help please
    Hey guys,
    I wanna put a gilmer belt drive on my vs statesman 5L. Is it hard to do? and ive heard that i'll loose my aircon!?.. can someone please give me some info/advise as to what i should be doing. thanks all
    VT
    Apr 2005
    QLD
    Are you having belt slip issues?
    If not, I would leave it as is.
    And yes, you won't be driving your air con compressor with a toothed pulley
    Vee-ard's Avatar
    Vee-ard is offline QuickVR95II 2010 Survivor
    Foam Tuned VR 5.0l Ute
    5 Miles 2 Go Champion!
    Jun 2009
    Bayswater, WA.
    They dont call gilmer belts the aircon and alternator destroyers for nothing. Be prepared to replace your alternator often.
    The hall of fame:
    Quote Originally Posted by lindsay.VS.Wagon. View Post
    ....a mini spool creates greater airflow to the engine which means more oxygen into the engine which adds greater combustion which adds an all around performance upgrade.
    Quote Originally Posted by edals View Post
    Also found running your lights all the time looses 100kms to a tank also.
    ಠ_ಠ
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    Die crest (on ebay) do a variety of kits to suit the 5L some use a combination of toothed and V belts for the various accesories
    Quote Originally Posted by Vee-ard View Post
    that's only because over tighten em
    Body by Holden, Soul by Brock
    the Legend will live forever
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    How will it loose air con? if you mean lose your air con, then no, you can get the adaptor pulleys to suit air con.
    Visit my Facebook page
    Home built Charged VS Commodore
    Apr 2010
    New Zealand
    Dont bother man I did It to a VS 5L and what a #### and it keeps costing for alternator bearings etc and end of the day it was only for the sound couse you cant drive round with a missing bonet to show it off. If your keen get a charger and an ADD on type set with the gilly that only runs the charger. good luck
    VR_Acclaim is offline Banned
    Vr acclaim
    Jun 2010
    I ran gilmers on a v6 and never had a drama but I had an adapter for the ac
    VS V8 UTE
    Mar 2008
    Hey mate. ive recently put one on my vs ute. you can buy the full kit on ebay to run your air con and power steering as well, (a.t. racing world) think it was about $270. they stay the original belt for the air con and power steering except they are running on the new pully. the new toothed belt runs your of your crank, water pump and alternator. everything will go on sweet, the only modification is you have to space the power steering out with longer bolts and get a few extra nuts to lock the bracket in. the bolts you will need are 3/8, 3 inch long x 3. dont over tighten your belt as you will have problems with the alternater bearings as previously said. you will also need a rattle gun to get the nut of the alternator to put the new pulley on. I also didnt put the ugly clutch fan back on, i picked up some twin au thermo fans for $140 and installed them..looks great, supercharger would be the go, but the gilmer drive still sounds cool anyway.. pretty straight forward job if youve got basic mechanical knowledge. good luck. Cheers Patto
    VS V8 UTE
    Mar 2008
    before i put my new engine in, i put the pulleys on so i guess it made it a bit easier.. also forgot to tell you that you will need longer bolts for the crank and water pump, so just take the old ones out and take them down to your hardware store and get the right length required to fit the drive.. easy as, good luck
    vs 5l ute
    Sep 2011
    perth
    hey mate im gonna get a gilmore drive kit for my vs ute from a.t racing. its says the kit doesnt come with bolts do i use my bolts or do i have to buy new ones if so where from what sort? also how do you space out the power steering with longer bolts do you put something behind the bracket that holds it on?
    woteva's Avatar
    woteva is offline NEED 4 SPEED
    VRII V6 Auto Wagon
    Jul 2005
    Adelaide S.A.
    Quote Originally Posted by timkel View Post
    hey mate im gonna get a gilmore drive kit for my vs ute.
    Is that the 'HAPPY' version you are getting ??
    Take out your old bolts and head down to your local fastners shop and ask for some longer ones.
    http://woteva.tk/
    If it ain't broke... I can break it for you
  1. Gilmer belt drive
    By AndyVKSSA in forum V8 Development and Modification
    Last Post: 28-12-2010, 05:04 PM
  2. Gilmer belt Drive kit
    By tunks1984 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-11-2010, 04:13 AM
  3. Gilmer Belt Drive + Aircon
    By Shtato in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-01-2010, 01:47 PM
  4. Gilmer belt drive on Vs ss?
    By andrewownsavp in forum V8 Development and Modification
    Last Post: 14-02-2009, 02:56 PM
  5. Gilmer belt drive
    By lo-rolla in forum V6 Development And Modification
    Last Post: 09-02-2009, 04:00 PM
Tags for this Thread
