Results 1 to 11 of 11
Thread: Removing harmony balancer advice
    VR_Acclaim is offline Banned
    Vr acclaim
    Jun 2010
    Default Removing harmony balancer advice
    Ok I bought a harmonic ballencer puller that bolts to the bdllancer not realising that u can't use it... Everyone has advised against a claw puller what sort do I need
    D3V14NT's Avatar
    D3V14NT is offline Likes Shiny Things
    93 VP BT1 V6
    May 2009
    Geelong, Vic
    I've always used a 3 armed claw type. Never had a problem.
    1. 1990 VN Exec V6
    2. 1993 VP BT1 3.8L - Now wrecking for parts!
    3. 1991 VP Berlina V8 - RIP
    Looking for a good condition VN - VS V8!!!
    vs commodore
    Oct 2009
    Tamworth NSW
    The 3 bolts from the puller screw into the harmonic balancer where the 3 slots ,or slot is around the front of the balancer.You need three 1/4 UNF type bolts to fit the thread thats in these slots.If you use a 3 leg type puller,it can destroy the balancer as the balancer is just made from inner an outer metal parts,joined together with a strip of rubber,so pulling the balancer from around the outside of it with a leg type puller can actually seperate the metal from the rubber part and destroy the balancer.
    jetboy's Avatar
    jetboy is offline You learn til u die
    VT exec
    Feb 2010
    Gold Coast QLD
    ^^^^^^^^^^^^^^^^ second that
    At 43 a wealth of info , but still heaps to learn
    VR Ute
    Jan 2010
    If it helps you can use a standard HB puller on it even though there is a special one for commodore HB's. You just need a piece of steel rod (hardened if possible) that goes up the centre of the HB, which is just smaller in diameter than the thread, so it slides straight in. Cut it off so it just protrudes about 1/2cm out the front when it is bottomed out in there (so it can be retrieved again) and put the middle of the puller on that and it will work a treat.
    stugdum
    vs commodore
    Oct 2009
    Tamworth NSW
    I didnt buy any special puller just for use on a commodore,Mines just a general 3 bolt type harmonic balancer puller.I got mine from supercheap for $30,It came with bolts,but none of them were 1/4 UNF ,so I got them from a local hardware store.It works excellent.Only takes a couple of minutes to connect it up and pull the balancer.
    jetboy's Avatar
    VT exec
    Feb 2010
    Gold Coast QLD
    Quote Originally Posted by Brett_jjj View Post
    ^^^^^^^^^^ Me too
    D3V14NT's Avatar
    93 VP BT1 V6
    May 2009
    Geelong, Vic
    Lucky I've only used it to remove and replace dodgy ones then haha
    1. 1990 VN Exec V6
    bpefi is offline Tech
    Hilux Ute - Vs Ecotech Engine
    Nov 2009
    Bundaberg
    Quote Originally Posted by Stugdum View Post
    stugdum
    Hi I just removed mine - went to borrow a puller from my mechanic - he just uses a large 2 leg puller - I had one but couldn't use it due to lack of room (its in a Hilux) He said that there where about three different types of pullers so I used a std harmonic balancer puller - just had to buy the bolts - I just loosened the centre bolt & screwed it out a bit instead of using the "steel rod up the center idea" just have to keep moving it out at times - came off pretty easy. Loosening the bolt is easy - just fit a socket & breaker bar on there & hit the ignition key.
    VP calais, VJ valiant, BG5 legacy
    Jan 2008
    New Plymouth, New Zealand
    You can use a claw type, Ive done it several times.
    The rubber is not the only thing holding the balancer together, there are bearings between the two metal parts - So even with all the rubber cut out they still stay together, there is just 15* or so movement between the inner and outer.
    Quote Originally Posted by QuickVRII95 View Post
    Elaborate, For All Of Us... How The Hell Is A Commodore A Friggin 4-Stroke...???
    Where Are You Getting Your Facts From...???
    You All ARE Wrong About A Commodore Being A 4 Stroke Engine... Or Any Car For A Matter Of Fact...
    A V6 CAN'T Run On ONLY 1 Cylinder... IT'S A 24 STROKE ENGINE... 4 CYCLES Per Cylinder... "Basically Three V-Twins Together
    Jan 2008
    stugdum
    Ive found leaving the bolt half threaded in works a treat, too.
  1. Removing Harmonic Balancer of mate's '93 VR
    By 1vngal in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-12-2010, 08:49 PM
  2. [Ecotec] really daft question about removing harmonic balancer
    By fuzzy2308 in forum V6 Development And Modification
    Last Post: 15-08-2009, 06:08 PM
  3. removing harmonic balancer
    By neilo 2 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-03-2007, 12:42 PM
  4. Removing harmonic balancer issue!!!!
    By smaddock in forum V6 Development And Modification
    Last Post: 19-02-2007, 11:53 AM
  5. Removing Harmonic Balancer
    By Meerkat in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-12-2006, 09:06 PM
