Results 1 to 5 of 5
Thread: will a VN T5 fit straight into a VS
    vs ute
    Dec 2010
    Launceston Tasmania
    Default will a VN T5 fit straight into a VS
    i can get a complete T5 removed from a vn
    will this fit into my VS ?
    if not what is needed to get the job done?
    thanks a million guys
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    most of it will fit what you'll need for your VS is a VS manual wiring loom and ecu. You will also need an VS T5 Ecotec Flywheel. You'll find these 2 are the hardest parts to find and the most expensive
    Quote Originally Posted by Smidy
    How many kw would i need to beat vin diesil to the train lines?
    vs ute
    Dec 2010
    Launceston Tasmania
    Quote Originally Posted by Pub247 View Post
    most of it will fit what you'll need for your VS is a VS manual wiring loom and ecu. You will also need an VS T% Ecotec Flywheel. You'll find these 2 are the hardest parts to find and the most expensive
    my vs is already a manual but it has a getrag ??
    Pub247's Avatar
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    If its a getrag i suggest you stick with it unless its broken. Some people have a preference to either one but i dont think there a lot of difference in some ways a getrag would be better for the hydrualic clutch.
    Being a manual already you wont need wiring loom or ecu (at least i assume theyd be the same whether its a t5 vs or getrag) So you'll need to find a t5 flywheel as getrags use a different one. You'd also need to change tailshaft yoke pedal box and remove the clutch Master cylinder. You need to change gearbox mount i assume and will need the manual short loom that connect to the reverse light and speed sensor wiring.
    It may be more trouble than its worth and i might have missed a few things along the way someone may help clarify some points about the conversion
    vs ute
    Dec 2010
    Launceston Tasmania
    ok this has all changed, seeing as my engine is a supercharged v6 it would actually be a series 2 vs - vx ecotech. are these different again to the earlier ones
    can a vn manual box bolt up to say a vt ?
    im learning know i would need a different flywheel and clutch conversion, just wondering about the actual bolt hole pattern on the bellhousing. cheers
  1. Straight Gas
    By Deutscher in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-04-2009, 12:12 AM
  2. Fit Straight In?
    By mrhotdog in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-10-2008, 05:40 PM
  3. vs v8 on straight lpg is it possible?
    By lil_oneblue in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-03-2007, 11:00 PM
  4. Straight through or not
    By ecotec38 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-01-2007, 09:11 PM
  5. LPG- Straight Gas
    By Davelxhatch in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-01-2007, 10:41 AM
