Hi guys tryed searching the forums and found out a few of the things i need to know all ready but as for the rest of my questions that werent answered , Will a vt/vx manual conversion getrag fit straight into my series 1 1995 vs commodore ecotech ? , what fly wheel bolt do i use for my series one vs , and will the vt/vx manual computer run my car properly , i can get a complete vt/vx manual conversion for 800 just dont want to buy it if its not going to fit my vs cheers guys .
1. VT-On wont fit into Pre VT cars with out modding the exhaust. Which is a pain as there ain't no room to run a good flowing exhaust. However the series 3 VS Ute runs the same box and has a modded bell housing and cover plate which allows you to run the factory VS exhaust.
2. VT-ON runs a New design Torque converter which cant be used with the Pre VT computers as what VT_Acclm has said about the software. There is a new valve design in the valve body but it the same shape and the VT just runs a better sleeve to stop ware in the bore.
3. there is no way the trans would work 100% if fitted in a VR the 3/2 kick down is totally different and the lockup is totally different the life span would be shorter than the correct box.
4. To fit into a VS the VS converter would need to be used and the Series 3 Ute bell housing would need to be fitted but i have never tried it and will never try it.
We ALL HAVE 1 THING IN COMMON:THE RELENTLESS PURSUIT OF GRIP
