Page 1 of 2 12 LastLast
Results 1 to 25 of 26
Thread: Signs of a blocked cat
    VR_Acclaim is offline Banned
    Vr acclaim
    Jun 2010
    Default Signs of a blocked cat
    Ok so my issue wasn't a cas I think I changed my coils leads an cam angle sensor.. Car runs really well but gets to 2300rpm and gets dulll but now revs threw it after 2 secs or so.. I was advised it could very well be a blocked cat what do u think
    bpefi is offline Tech
    Hilux Ute - Vs Ecotech Engine
    Nov 2009
    Bundaberg
    Leave it till its cold (they get very hot at times) & hit it with a rubber hammer or your hand usually they will rattle if they are failing as the ceramic comb breaks up - other than that - pull it out & have a look as its good to know how good its condition is - usually there is only 2 bolts each end - use some sensor safe silicone to reseal it after wards.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    From my experience with blocked cats, it will rev to a certain speed and stay at that speed - it will not increase after a few seconds......then gradually over a few days the top revs will drop till it basically will only idle. Have you done a fault codes check?
    soop is offline Banned
    2003 SS Commodore Series II
    Nov 2008
    Smithton, Tasmania.
    If the catalyst is moving around you can hear it through the exhaust. Sounds like someone putting a potato over the pipe on and off.
    VX S S/C & BA XR6T
    Feb 2009
    Nov 2008
    Smithton, Tasmania.
    Vr acclaim
    Jun 2010
    Done codes got nothin it run fine but gets to 2500 and gets Spey an then it works threw it which up
    Untill the leads today it didn't maybe plugs?
    Nov 2009
    Bundaberg
    Vr acclaim
    Jun 2010
    Sorry ok so yesterday it would rev to about 2700 and wouldn't go further just slaves..today I've replaced leads and coil...and it works threw the dead spot..yesterday it stalled and wouldn't idle or do anything.. It free revs in neutral...I was thinking maybe a fudged plug??
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Maybe have a look at the engine when you bring it up to the revs where it stalls at night during total darkness - this will show up any high voltage leakage from plugs/leads/coils....look for the blue sparks.
    As a wildcard suggestion, try resetting the ECU by disconnecting the battery for 30 seconds....stranger things have been known to happen.
    GTP 85's Avatar
    GTP 85 is offline 291 hp @ the wheels
    VS track car & VS SSenator
    Aug 2006
    Adelaide, near the bay
    fuel pump maybe? or fuel filter??
    Hit me up with some reputation points if i've helped you out! (Star in the bottom left!) Cheers!
    GT Performance RUF 231- NA 3.8L- 13.30 @ 103 Mph... So far... Cam, compression and revs! MY CAR>> http://forums.justcommodores.com.au/...tml#post471410
    Daily VR SS: http://forums.justcommodores.com.au/...ite-vr-ss.html
    jetboy's Avatar
    jetboy is offline You learn til u die
    VT exec
    Feb 2010
    Gold Coast QLD
    From my experience ,best an easiest way , an thats without pullin anything apart an gettin dirty etc etc . Is to get ur mate to give it a few darn good revs whilst u hold ur hand over the tailpipe , then look at your hand , if its got all goldie lookin specks all over it that twinkle in the sun . Your cats stuffed , give it a go . Personally , i took mine off knocked the guts clean out of it an threw the empty shell back on the car , looks the part but there aint nuthin in there .Gives a bit more grunt , prob not much but enough to peel the doors of a XR6
    At 43 a wealth of info , but still heaps to learn
    jakstas's Avatar
    jakstas is offline Auto Elec
    VT SS S2 M6
    Jul 2006
    Vee-ard's Avatar
    Vee-ard is offline QuickVR95II 2010 Survivor
    Foam Tuned VR 5.0l Ute
    5 Miles 2 Go Champion!
    Jun 2009
    Bayswater, WA.
    The inside of the cat isnt enough of a restriction to slow even a V8 let alone a stock V6. knocking it out wont get you anything except a MASSIVE fine when the cop with the infra red gun points it at the cat and sees its too cold to have an inside. Its no faster at all.
    People who knock out the guts out of cats are in the same category as people who cut springs.
    The hall of fame:
    Quote Originally Posted by lindsay.VS.Wagon. View Post
    ....a mini spool creates greater airflow to the engine which means more oxygen into the engine which adds greater combustion which adds an all around performance upgrade.
    Quote Originally Posted by edals View Post
    Also found running your lights all the time looses 100kms to a tank also.
    ಠ_ಠ
  15. #15
    jetboy's Avatar
    VT exec
    Feb 2010
    Gold Coast QLD
    Ppppphhhhhhffffffttttttttttttt
  16. #16
    jetboy's Avatar
    VT exec
    Feb 2010
    Gold Coast QLD
    Quote Originally Posted by Vee-ard View Post
    Rito champ dyno ur car wuth the cat on , then dyno it with a "gutless" cat , see the results for urself > better still POST EM > prove me wrong................................
  17. #17
    D3V14NT's Avatar
    D3V14NT is offline Likes Shiny Things
    93 VP BT1 V6
    May 2009
    Geelong, Vic
    Quote Originally Posted by jetboy View Post
    Do you have dyno figures to show that gutting the cat DOES do anything? Works both ways.
    Plus I've heard from a few places that gutting the cat gives the exhaust a crappy tinny noise.
    1. 1990 VN Exec V6
    2. 1993 VP BT1 3.8L - Now wrecking for parts!
    3. 1991 VP Berlina V8 - RIP
    Looking for a good condition VN - VS V8!!!
  18. #18
    D22 St-r Navara
    Dec 2010
    perth
    nothing wrong with cutting springs, knocking out cats or putting milo tins on the exhaust. its cool just like smoking menthols
  19. #19
    IMCRZY's Avatar
    IMCRZY is offline RESPECT!
    M6 Hazzard SV6
    Mar 2007
    Wollongong
    Quote Originally Posted by VR_Acclaim View Post
    Just undo the exhaust before the cat and rev it,
    Revs as normal = Blocked exhaust
    I WISH MY GRASS WAS EMO SO IT WOULD CUT ITSELF
  20. #20
    Vr acclaim
    Jun 2010
    I had an idea and my fiancé. Thinks the same could it be the box as it dragging threw the 3rd gear
  21. #21
    jetboy's Avatar
    VT exec
    Feb 2010
    Gold Coast QLD
    No crappy tinny noise here , matter a fact everyone comments on my "note"
  22. #22
    Holden VS Series II 1997 Ute - 5 Speed Manual
    Aug 2008
    Im sure the cops would too when they catch you :P
  23. #23
    jetboy's Avatar
    VT exec
    Feb 2010
    Gold Coast QLD
    Im a family man an drive sensibly , i dont go out cruizin the streets at night them days are over for me . I have'nt been pulled over in a good 8 years , an only been booked once in the past 16 yrs or so , had no gutts in the cat for a good 6 , an besides coppers up here in QLD arn't as anal about the pollution shit as their southern counter parts .
  24. #24
    vs commodore
    Oct 2009
    Tamworth NSW
    I live in the country,so maybe these catalytic converter tests happen less frequently up here,but Ive never even heard of anyone getting busted or fined or whatever for a non working catalytic converter.Ive heard some ridiculous things that people have been busted for,but never for a non working cat.Ive noticed whenever someone mentions anything about a gutted cat on here,people go on about how you will get this big fine etc etc,if it were as common as any other defect,surely we would hear about it more often,even in the country.They dont even check the cats operation at rego time.Also if its replaced when the exhaust system is replaced,you should never have trouble with it getting blocked,unless you hit something on the road that smashes the catalyst inside it.I know theres a lot of young blokes around here who have gutted their cat believing it goes better or sounds better whatever,Ive been in a few of these cars and there seems to be very little gain,if any, in performance over the same car with a working cat installed.It doesnt even seem to change the sound that much really either.I dont run a gutted cat.
  25. #25
    D3V14NT's Avatar
    93 VP BT1 V6
    May 2009
    Geelong, Vic
    They don't get checked very frequently. They sometimes check them when they do the big roadside roadworthy testing operations and they sometimes ask people they pull over to come in on blah day to get it checked. Usually you'll only get asked to have it checked out if you're a twat to the cop or they have good reason to think you've damaged/gutted/whatevered them.
    Fines can vary greatly. Lack of or improperly functioning cats make the car unroadworthy which can leave you open to fines from the police, which is a few hundred or so depending where you live. However if the fine comes from the EPA from the emissions laws the fine can be several thousand. All depends who's doing the testing/fining and how much they like/dislike you.
    1. 1990 VN Exec V6
  1. signs of a blocked catalytic converter
    By bandit10 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-04-2010, 06:14 PM
  2. blocked injectors
    By shan thorn in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-08-2009, 05:38 PM
  3. Please help, VT V6 blocked vents, where to look next?
    By jonnydico in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-03-2009, 06:34 PM
  4. blocked nose
    By tmaybz in forum Jokes/Humour
    Last Post: 06-11-2007, 06:13 AM
  5. blocked thermostat?
    By fantasy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-10-2005, 09:07 AM
