Results 1 to 7 of 7
Thread: vs series 2 auto sedan wont start / no starter sound at all
    vx berlina
    Aug 2005
    gladstone
    Default vs series 2 auto sedan wont start / no starter sound at all
    hi guys i went to start my vs series 2 v6 auto after work and there was nuthing ,the dash lights come on but i turn the ignition all the way to start and theres nuthing at all no click no starter motor crankin its just dead quiet ,im pretty sure i can hear the fuel pump priming but where the car is parked is abit loud so was hard to tell,the headlights seem strong [heaps of power], i checked the fuses they seemed good not sure about the relays but i think there all original from 1997. 1 thing my car has done for at least 2 or 3 years is it usally doesent start straight up ,its like the starter motor is turning over real slow/sluggish and struggling for a few seconds , then sumtimes it just starts pretty much straight up nice and sharp could the starter motor just died ? the alternator and battery are about 3 years old i havent checked computer codes yet but i will when i go to work in the morning where my car is parked just after any ideas plz guys cheers muz o and the crank angle sensor is only about 12 months old also the battery in my key is like 5 years old not sure if it works cause the buttons are gone could this have anything to do with the ignition ?
    VS Executive series 2
    Nov 2010
    It could be the starter motor itself or the wires connecting to the starter motor could be loose. Also you can check neutral start switch or ignition barrel.
    93 VR Executive Wagon
    Mar 2009
    Melbourne, Bentleigh East
    VSII EXECUTIVE WAGON
    Dec 2010
    Callala Bay NSW
    Hi Muzza
    Try locking the car with the central locking then unlock then try to start. If this works you probably just have to get a new key.
    vx berlina
    Aug 2005
    gladstone
    ok i just drove into where my car is and it starts perfectly , first i tested the central locking to c if the keys batterey was flat it worked then i started the car a few times no problem ,i should of mentioned that the 2 buttons on the key remote fell out ages ago and i made sum new ones with foam ear plugs cut down to fit in the 2 holes and then taped over lol dont laugh it worked for ages but today i redid the foam [buttons]i made and i think one of them [the unlock or lock button might have been stuck in , any 1 no if that would hurt the signal the remote needs to start the car ?
    VS Berlina soon to be 5L
    Aug 2010
    Girrawheen
    if it was stuck in lock might do, but needs to key head battery to be ok to work.
    Vee-ard's Avatar
    Vee-ard is offline QuickVR95II 2010 Survivor
    Foam Tuned VR 5.0l Ute
    5 Miles 2 Go Champion!
    Jun 2009
    Bayswater, WA.
    My guess is your park-neutral switch is on the fritz. Car wont start unless it knows its in park or neutral.
    The hall of fame:
    Quote Originally Posted by lindsay.VS.Wagon. View Post
    ....a mini spool creates greater airflow to the engine which means more oxygen into the engine which adds greater combustion which adds an all around performance upgrade.
    Quote Originally Posted by edals View Post
    Also found running your lights all the time looses 100kms to a tank also.
    ಠ_ಠ
  1. vt wont start (immobiliser or starter motor) please help.
    By evilhighway in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-08-2010, 08:55 AM
  2. VT wont start ??? starter motor ??
    By Miss L in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-08-2010, 08:04 PM
  3. wont start, starter motor won even try to crank
    By vs1997II in forum Electrical Wiring / Questions
    Last Post: 30-06-2010, 09:31 PM
  4. VR series 2 wont start
    By im blonde? in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-08-2009, 11:26 PM
  5. Help! My 1985 VK Holden Commodore Sedan wont start!
    By lucielrenegade in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 28-04-2009, 02:51 PM
