Results 1 to 8 of 8
Thread: VS / VT valves & seats - hardened??
    bpefi is offline Tech
    Hilux Ute - Vs Ecotech Engine
    Nov 2009
    Bundaberg
    Default VS / VT valves & seats - hardened??
    Anyone got any idea of what the go is with VS / VT seats & valves - running LPG & Flash lube as a precaution ATM - heads coming off soon & I need to know what to do - about time there was an LPG section here too - would be great if someone knows who to chat with about it...Also are all the Ecotec heads that same size -are any smaller at all ?? Want to go up in compressions..
    VZ R8. VS II L67 M5. VT International Calais L67.
    Aug 2008
    NSW South Coast
    vs-vy heads are all the same and interchangable. The seats are hardened, however, different seats can be installed for better life with lpg applications. Would be worth having a chat with a reconditioner about these. You've got 2 options to increase compression on an ecotec, either with pistons or shaving the heads. If you do shave the heads you'll also have to get the alloy inlet manifold shave down accordingly aswell.
    Z' Series HSV 297KW 6lt LS2 Conversion For Sale!
    PM Me For Details
    Nov 2009
    Bundaberg
    Quote Originally Posted by cander24 View Post
    Thanks for the reply
    Nov 2009
    Bundaberg
    Went out looking for a motor today in the way of a VT - wreckers claim they crack heads a lot - says they look ok but after engine re conditioner looks at them - they claim that their stuffed - personally through my workshop I have never seen any problems - anyone got a comment on this??/
    The1's Avatar
    The1 is offline A Memcal a Day Keeps..
    VS V6 Berlina Auto Series 1
    Jan 2005
    Toowoomba QLD
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    my wrecker also says that a lot of ecotecs have cracked heads but i've not really ever seen any
    Body by Holden, Soul by Brock
    the Legend will live forever
    Nov 2009
    Bundaberg
    Well personally - I have replaced a few v6's with noises in them - but never had one apart - I suppose where I was working it was a majority of Fords there at the time & I was known to be a Ford mechanic though I had worked on many other brands at dealers as well. Fitted plenty of complete reco engines - I suppose nowadays you only have apart what your inclined to modify or if your at a dealer under warranty - though never needed to pull heads off & done thousands of Fords head gaskets & heads. I was predominately behind the counter for a long time as well...
    Nov 2009
    Bundaberg
    Well went an engine reconditioner today - it appears they crack through in between the seats - apparently very hard to find good heads - I dont know why they cant use larger seats though & machine that area & overlap the valve seats - I am sure someone will have a fix for them - found the problem with the motor - had a sump gasket replaced just before the motor problems started - had a look at the oil pickup this morning & they have managed to get silastic on the oil pickup & its restricted oil flow severely to the oil pump. Wonder full & every ones closing for Christmas - nice present indeed...
  1. EGR and PCV VALVES
    By maccasparks in forum VY Holden Commodore (2002 - 2004)
    Last Post: 08-01-2011, 05:32 PM
  2. hardened push rods
    By eaton v8 in forum V8 Development and Modification
    Last Post: 03-06-2010, 08:36 PM
  3. Remove hardened(cured) silicone from paint???
    By blakerv8 in forum General
    Last Post: 14-01-2010, 08:14 PM
  4. tx valves
    By cinndaz044 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-12-2009, 09:59 AM
  5. valves
    By jamiekratin in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 23-01-2006, 12:18 PM
