Results 1 to 16 of 16
Thread: Removing harmonic balancer.
    vs berlina s2
    Feb 2009
    Default Removing harmonic balancer.
    Tried a 1/2 inch rattle gun. on a 100l 5hp air compressor....FAIL. Tried to use a breaker bar Fail. bend my sidchrome breaker bar when i cranked the engine. its that tight....any ideas?
    The1's Avatar
    The1 is offline A Memcal a Day Keeps..
    VS V6 Berlina Auto Series 1
    Jan 2005
    Toowoomba QLD
    you'd be outta luck if those two dont work, i have heard of people using an oxy to heat up the bolt a little then give it a whirl.
    nstone63's Avatar
    nstone63 is offline wants a new car
    1988 VN Executive
    Mar 2010
    Roxby Downs SA
    I had to keep going with mine by using the breaker bar and cranking the engine.. maybe just keep alternating those two methods? try and gradually work it loose
    vs berlina s2
    Feb 2009
    Ok so its deffently a bastard of a thing to remove. and i havnt got something outta the ordanary
    vs berlina s2
    Feb 2009
    The1's Avatar
    Jan 2005
    Toowoomba QLD
    i havn't done it myself, but im guessing the idea of it was to heat it up enough that any greases would start to let go which wouldn't be very hot, would only take a second or two from an oxy
    vr stroker v6
    Jan 2009
    townsville qld
    vs berlina s2
    Feb 2009
    D3V14NT's Avatar
    D3V14NT is offline Likes Shiny Things
    93 VP BT1 V6
    May 2009
    Geelong, Vic
    I jammed a metal plate in between the flywheel and the starter motor opening. Then preceeded to place a breaker bar on the bolt with a bit of pipe on the end and belted it with a hammer. Cracked it after a few spirited hits.
    1. 1990 VN Exec V6
    2. 1993 VP BT1 3.8L - Now wrecking for parts!
    3. 1991 VP Berlina V8 - RIP
    Looking for a good condition VN - VS V8!!!
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    Itry the above method if using engine and breaker bar dont work i usually let the breaker gain some momentum before it hits the chassis as you want that crack to happen
    Heating the bolt aint ever going to work heat expands metal go buy some loctite freeze and release then retry the above method or engine cranking method garuntee itll work
    Quote Originally Posted by Smidy
    How many kw would i need to beat vin diesil to the train lines?
    bpefi is offline Tech
    Hilux Ute - Vs Ecotech Engine
    Nov 2009
    Bundaberg
    Hey - you need a good sized punch & a heavy hammer 1/4 pounder is best as anything else will do nothing & give the end of the bolt a couple of almighty whacks - should be enough room in front of the engine - don't leave breaker bar loose as it can fly off & damage something - use a single hex socket as well if you can. Heating will do nothing unless it can work its way down the bolt & you will damage the harmonic balancer this way. More than likely it might have loctite on it & if that is the case heat will be the only thing - just do not go overboard with it.
    vs berlina s2
    Feb 2009
    Rattle gun and a bernzomatic gas torch headed the head of the bolt hit it with the rattle gun and off she came
    vs berlina s2
    Feb 2009
    VP calais, VJ valiant, BG5 legacy
    Jan 2008
    New Plymouth, New Zealand
    Use a 3/4" bar with a pipe over it
    Quote Originally Posted by QuickVRII95 View Post
    Elaborate, For All Of Us... How The Hell Is A Commodore A Friggin 4-Stroke...???
    Where Are You Getting Your Facts From...???
    You All ARE Wrong About A Commodore Being A 4 Stroke Engine... Or Any Car For A Matter Of Fact...
    A V6 CAN'T Run On ONLY 1 Cylinder... IT'S A 24 STROKE ENGINE... 4 CYCLES Per Cylinder... "Basically Three V-Twins Together
  15. #15
    vs commodore
    Oct 2009
    Tamworth NSW
    The easiest way Ive found to loosen this bolt is to fit a breaker bar and socket on the bolt,rest the breaker bar on the chassis rail or on the ground and crank the engine over.Ive done it heaps of times like this and it works excellent.Its a good idea to remove the EFI relay or engine fuse so the engine can only crank over,you dont want it to actually start whilst doing this..
  16. #16
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    i use a 3/4" socket set and get em loose every time. i also have a steel bar with a couple of bolts in it that fits into the holes in the balancer that i use to stop the engine turning over when using the afore mentioned socket set.
    Body by Holden, Soul by Brock
    the Legend will live forever
  1. Removing Harmonic Balancer of mate's '93 VR
    By 1vngal in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-12-2010, 08:49 PM
  2. [Ecotec] really daft question about removing harmonic balancer
    By fuzzy2308 in forum V6 Development And Modification
    Last Post: 15-08-2009, 06:08 PM
  3. removing harmonic balancer
    By neilo 2 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-03-2007, 12:42 PM
  4. Removing harmonic balancer issue!!!!
    By smaddock in forum V6 Development And Modification
    Last Post: 19-02-2007, 11:53 AM
  5. Removing Harmonic Balancer
    By Meerkat in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-12-2006, 09:06 PM
