Hi guys
Looking to find the evap temp sensor in a VR calais. Im having trouble with the CC. On a long trip the air flow gradually slows and then all but stops. If I turn off the A/C but have the fan running after about 10min the air flow gradually starts again and eventually is fine. I think the thing is freezing over and stopping air flow? If anyone else has overcome this issue I would be greatfull for some assistance
have reed thru this forum? may be of some help to you>>> Air Con issues
We ALL HAVE 1 THING IN COMMON:THE RELENTLESS PURSUIT OF GRIP
The climate control fan motor has 10 speeds controled electronicly (normal fan has 4 speeds) and 3 speeds controlled manually. If the system is on auto and the sensor is thinking the cab is cold it drops the fan speed accordingly. Do you run the system on auto? If not try that.
and 3 Dangerous non ABS VN's
