Results 1 to 9 of 9
Thread: VS Aerial Module
    Super Coach's Avatar
    Super Coach is offline VS S Pak, Monaro CV8Z
    VS Commodore S, VZ Monaro CV8Z
    Jul 2006
    Default VS Aerial Module
    Hi I’m having a problem with my aerial module! The problem is when I turn the car off or the radio off the aerial goes down fine like it should. But when I turn the radio back on or turn the acc back on the aerial goes up only about 4cm then it stops. I hear like a clicking noise coming from the module when this happens as if the timer has kicked in to stop the aerial at that point. I then have to use the up button to get it all the way up. Its connected to the original head unit and is on the factory fitted loom. The aerial is the eletcric Aerpro, but somehow I think the module is playing up
    Where is the problem? Is there away in setting the height you want for the aerial??? Or resetting the timer on the module, or is my module stuffed!!!!
    can anyone help me out here with info on this module?
    Super Coach
    justbad4you's Avatar
    justbad4you is offline IF YOR NOT A HOLDEN
    97 VT BERLINA/ 98 VS SIII MALOO (RED) LX SLR5000
    Sep 2005
    MELBOURNE S/E BAYSIDE
    VS_Pete_1's Avatar
    VS_Pete_1 is offline Donating Member
    VE II SV6 MY12 Sportwagon
    Dec 2007
    Mate I replaced mine with a aerpro and just goes up and down because it is fully automatic not semi automatic like the holden one.
    Here is a reply I got from Luke
    VS Aerpro replacememt Aerial.
    Can`t help you with the rest.
    Mybe you should post this in the Audio section.
    "Success is the ability to go from one failure to another with no loss of enthusiasm" Sir Winston Churchill.
    My VS II Berlina Wagon
    MY12 II SV6 Sportwagon
    MR.HG's Avatar
    MR.HG is offline makin teh mods QQ
    VSIIBerlina, HG Brougham
    Dec 2010
    mate that clicking noise is the toothed cable inside the mast clicking on the retract/extend mechanism
    Growing old is inevitable, Growing up is optional.
    View my - 97 VS Berlina series2 http://forums.justcommodores.com.au/...ml#post1738670
    - 70 HG Brougham Project http://forums.justcommodores.com.au/...-brougham.html
    D22 St-r Navara
    Dec 2010
    perth
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    Suggest you replace it. The Aerpro on my Calais (replacement of the OEM original) only seemed to last around five years. Started playing up and steadily got worse. Only good thing is the brackets from the current Aerpro can be used which saves some mucking around.
    MR.HG's Avatar
    Dec 2010
    db_notso's Avatar
    db_notso is offline diagnostic technician...
    vt v6, mods(susp brakesetc...)
    Oct 2010
    sunshine coast, qld
    if the motor goes up all the way but wont come back down its either
    a rope and mast - as the teeth on it are worn (in the direction that takes more force)
    OR
    motor assmly(comes with mast)- as the gearing can move in and out after lot of wear causing it to slip off the gear inside the case
    VS Series11 Ute
    Jan 2005
    When it's fully extended, get a rag soaked in turps, thinners, degreaser or something like that, clean the mast very well, get rid of the grey stuff and have the stainless steel shining, and then give it a spray or rub a rag soaked in WD40 or something like that on it. Fixes most of the electric antenna problems.
  1. interchaning Vy s1 berlina climate control panel/module with VZ module
    By mudmutt in forum VY Holden Commodore (2002 - 2004)
    Last Post: 24-04-2010, 02:54 PM
  2. FS [VIC]: power arial module and centrol locking module
    By georgeonboost in forum Parts And Other Items For Sale
    Last Post: 24-09-2008, 06:41 PM
  3. VS Aerial Control Module
    By tjilpi in forum Electrical Wiring / Questions
    Last Post: 04-10-2007, 09:11 AM
  4. VS Electric Aerial Module
    By tjilpi in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-10-2007, 06:32 PM
