Results 1 to 8 of 8
Thread: INTERIOR fan always on
    Maroon VS Greg Norman Statesman/1986 Suzuki Sierra
    Nov 2009
    Blaxland, NSW
    Default INTERIOR fan always on
    Hi guys, got to my car today and it started up as if it had a low battery,
    I go to start it this afternoon, and before i even put the key in, the car is blowing air through the AC vents,
    so i started the car (just turned over) and turned the air con/fan/climate control/everything off, and it stayed on,
    and in fact came on with a bit more force when i turned the ignition/accessories and everything off and pulled the keys out, it has never done this before and the radio follows remote and turns off when reds are off so why doesnt the fan do the same?
    I just went out the to the car then, and the battery is dead, the car wouldnt unlock. I plugged the battery charger in, and even though it still barely has any power to unlock the doors, its still blowing a little bit of air.
    The car is a 1996 VSII Statesman V6, has anyone got any idea what could be happening and how I could fix it or if any one has experience this before. Thankyou
    db_notso's Avatar
    db_notso is offline diagnostic technician...
    vt v6, mods(susp brakesetc...)
    Oct 2010
    sunshine coast, qld
    sounds like the fan is shorted to earth between the fan and the switch
    like a pinched wire changed anything in the dash lately start there!~ look for a crushed wire
    unplug the fan, run car half hour and drive it a bit (leave unplugged)
    then leave it overnight and see if it drains flat again it shouldnt if its shorted between the fan and the switch switch is earthed when ign not off
    so shouldnt work when ign off!~
    Nov 2009
    Blaxland, NSW
    db_notso's Avatar
    Oct 2010
    sunshine coast, qld
    is a good place to start if unplugging it stops fan then is goin to be shorted
    apart from visually following wires you need a multimeter to find the short after that
    keeny's Avatar
    keeny is offline keeny
    vz calais alloytec 190
    Dec 2008
    Maitland, NSW
    remove the blower relay, it should stop the fan, in vt-vz its under the steering wheel. possibly called inhibitor relay?
    accentstencil's Avatar
    accentstencil is online now Donating Member
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    The blower relay could be stuck in the on position, try changing it
    MY RIDE
    VS Berlina S2
    Feb 2010
    I had this same issue with my VS Berlina. Ended up being the fan speed resistor.
    wamboin23's Avatar
    wamboin23 is offline Donating Member w/ Boost
    VS Calais - L67 + T5 | VR Acclaim V6
    Apr 2009
    Wamboin, NSW
    will be the fan speed amplifier. pretty common for them to fail in that way.
    can buy a new one from holden, or if you PM The1, he has the parts to repair them for you, cheaper than you can buy them new.
  1. Interior kits or changing Interior
    By iRiot in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-11-2011, 08:54 AM
  2. opinions on going the red interior? / looking for a few red interior parts
    By VLC86 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 05-11-2010, 07:32 AM
  3. vs interior change please help/ upgrade/ buying new interior.
    By jadder in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-10-2010, 03:45 PM
  4. [VIC] F/s vs calais interior half leather & vs statesman series 1 interior
    By BT1-355 in forum Parts And Other Items For Sale
    Last Post: 28-04-2010, 10:24 PM
  5. VK Cerulean interior and VK Calais Blue interior
    By BlackCaprice in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 10-07-2009, 05:12 PM
