Results 1 to 2 of 2
Thread: trac control fault lights
    vt calais
    Jul 2009
    Default trac control fault lights
    hi just have a problem with my calais had the trac control and abs fault lights come on and also lost my power steering for a few minutes then lights went out and car went back to normal for about half an hour or so and then proiblem reappeared anyone have any ideas would be very gratefull
    RX25SE's Avatar
    RX25SE is offline Real cars are steel cars.
    vsII acclaim wagon
    Jan 2009
    May be a control unit fault causing the CAN (the network the computers use to communicate) to drop out. From memory its usually the ABS control unit that plays up. This causes most of the dash warning lights to come on and the Air Con to drop out. The fault will not usually log a code so a scan tool won't pick it up.
    Also, this might go better in the VT-VX forum.
  1. No trac control button??
    By wicksy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-08-2010, 01:44 PM
  2. trac control button and heater control lights!
    By mrVT in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 29-04-2008, 09:07 PM
  3. ABS, Trac Control and Engine Warning Lights
    By aborchy in forum Electrical Wiring / Questions
    Last Post: 19-12-2007, 09:49 AM
  4. how to get rid of trac control
    By Whitevtberlina in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-01-2006, 02:14 PM
  5. ABS/Trac Control lights
    By digitok in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-05-2005, 09:31 PM
