Hi i was wondering if this is true. A local wrecker told me that fitting a vt seats into a vr wagon is illigal due to the vt seat having a gassed cartridge on the seat belt buckle which engages in a accident making the seat belt push right down to hold you in the seat. I noticed a vt seat seating there with what looks like a cartidge next to the buckle on a drivers seat.
Is this true that these when installed wrong can possibly kill you or a child thats in that seat.
OR is this guy telling me a crock off s**t ?
Another thing is do these seats bolt straight into a vr wagon by that i mean the railings and do the bolt heads line up the same as a vr seat ?
thanks
Modifying a car is like a drug once you start you cannot stop
Holdens if your not in one your behind one
U use ur rails n seat belts so the vt belts have nothing to do with it
In Vic to fit seats not offered by the manufacturer for a particular model would require an engineers certificate to be roadworthy.
The gas cartridge is a seat belt pre-tensioner, used to compensate for the 'spooling' of the rolled up portion of the belt.
Thanks so would it be possible to use the vt rails and seat belt ? Are these cartridges dangerous when used in a vr ?
Here is a link to the "how-to" - that will answer all your questions and show you how to do it: VT/VX RetroFit Guide for: VN/VP/VR/VS
Cool thanks for that.
