Results 1 to 5 of 5
Thread: Heater working but not blowing from air vents - VR
    SiKC.VR's Avatar
    SiKC.VR is offline hoon
    VR Berlina
    Jun 2010
    Question Heater working but not blowing from air vents - VR
    My heater core is not clogged, both hoses in and out are hot but there's no heat coming from the dash or under the dash (feet) but the fans are working and only air blows out created by the fans....
    though while i was replacing the carpeting, i accidentally broke off a piece from the plastic where the heater core housing sits which was a screw holding the lines for the rear vents (see pictures) and surprisingly when the heater is on, the heater only blows out of that hole whilst cold air blows from the actual vents
    any suggestions would be great! thanks.
    Attached Thumbnails Attached Thumbnails Heater working but not blowing from air vents - VR-file0580.jpg   Heater working but not blowing from air vents - VR-file0583.jpg
    nathanVY's Avatar
    nathanVY is offline need boost...
    03 VY Calais, 99 VT Equipe
    Dec 2009
    Geelong, VIC
    Try replacing your vac solenoid box, not too expensive from the wreckers. I think holden still sell them new but theyre a bit more pricey.
    Vac solenoid box is underneath the cd player area see photos in my thread for what it looks like, they often leak. Also check all the hoses in your engine bay ( vac hoses) if they're old and perished replace them, also check the one way valve (not sure if VRs have this the VS does) and the T-Piece. Definitely a vacuum problem anyways.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    At a guess, I'd say the bit of plastic you broke off is allowing all the hot air to escape out the hole as you describe rather than travel further and out the vents. I would glue the piece back in or somehow block that hole.
    SiKC.VR's Avatar
    VR Berlina
    Jun 2010
    Before i broke it, it didn't work which made me thing there was a problem with the heating system itself, but since its blowing hot air from that hole i broke and not the vents, i now know that the heater does work but its not getting to the vents so it should have something to do with the vacuum as nathanvs said above, im going to have it looked at by my mechanic and let you guys know!!
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Quote Originally Posted by SiKC.VR View Post
    OK - your original post didn't mention that it didn't work before you broke it - sounds like one of the vacuum solenoids is not opening the hot air flap...possibly dislodged vacuum line.
    By the way, does your car have standard A/C or climate control?
  1. VN Heater/Vents not hot
    By Pickled in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-09-2010, 10:48 AM
  2. VL Vents not blowing
    By Ranga in forum VL Holden Commodore (1986 - 1988)
    Last Post: 02-06-2010, 08:43 PM
  3. Noise coming from heater vents
    By shinagami2227 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-11-2008, 07:24 PM
  4. front air/heater vents
    By slayer in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-09-2006, 03:03 PM
  5. my heater is blowing air temperature
    By joeyvk in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 01-07-2005, 07:31 PM
Tags for this Thread
