Results 1 to 5 of 5
Thread: WARNING : Idler/tensioner pulley replacement
    MR.HG's Avatar
    MR.HG is offline makin teh mods QQ
    VSIIBerlina, HG Brougham
    Dec 2010
    Default WARNING : Idler/tensioner pulley replacement
    If you are replacing these pulleys and your fan belt is slightly worn, change your belt too. My belt wasn't that bad but it was enough to throw it out of its groove, spit off, tangle up around the crank and rip the crank angle sensor clean out of the block, on top of that bent the fins??on the harmonic balancer that the sensor reads and had to replace the balancer as well.
    Growing old is inevitable, Growing up is optional.
    View my - 97 VS Berlina series2 http://forums.justcommodores.com.au/...ml#post1738670
    - 70 HG Brougham Project http://forums.justcommodores.com.au/...-brougham.html
    The1's Avatar
    The1 is offline A Memcal a Day Keeps..
    VS V6 Berlina Auto Series 1
    Jan 2005
    Toowoomba QLD
    VS Berlina S2
    Feb 2010
    I wouldn't have thought a slightly worn serpentine belt would be the reason it got thrown off the pulleys. I would have gone for out of alignment pulleys or incorrectly installed belt. Not saying what you said is untrue.......just saying I am somewhat surprised. How long after you installed the new pulleys did it take for the belt to throw the towel in?
    bpefi is offline Tech
    Hilux Ute - Vs Ecotech Engine
    Nov 2009
    Bundaberg
    Quote Originally Posted by VSHeaven View Post
    I would be inclined to agree with this too - refitted many without problems - I would be checking alignment of everything...
    MR.HG's Avatar
    Dec 2010
    was a few days of driving after it threw the towel in, installed the belt according to the owners manual and i only replaced the idler and tensioner, ran it with the hood up and everything looked fine. However i didnt thoroughly inspect the belt but i have had ones that seem to appear worse in other vehicles work just fine.
  1. Idler Pulley Q
    By raovq in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-06-2010, 06:06 PM
  2. VN tensioner pulley assembly replacement
    By beno85 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-05-2009, 03:59 PM
  3. Tensioner pulley replacement
    By tezza in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-04-2008, 06:21 PM
  4. VN belt idler Tensioner complete
    By futronix in forum Parts And Other Items For Sale
    Last Post: 16-12-2006, 11:41 PM
  5. Idler tensioner?
    By hunny_2541 in forum General
    Last Post: 29-07-2005, 11:56 AM
