Results 1 to 2 of 2
Thread: VR Water Pump Hose
    VY Executive S1
    Dec 2010
    NSW
    Default VR Water Pump Hose
    Ok there is a small plastic tube coming from the engine that you attach a hose from the water pump to this now that has broken off, the plastic thing (lol abbreviations are cool) is attached by a small bolt so where i'm guessing its attached by a bolt cause it was expected by holden that this might happen so where can i get this part supercheap repco.
    Any help will be much appreciated...
    VR V6
    Mar 2011
    sydney
    i just had to do the same job on my vr and i had to go to holden to get part it cost me $20.00 4 new hose rubber o ring and plastic fitting which like u said bolts to the manifold,theres also one one at the back which might b worth changing at the same time i had to take my thero hiusing off also as some of the broken plastic went inside the manifold when i was removing the old one,prob be better if u hav nt already done it too remove the manifold itself n replace the gaskets under it that way u can get both plastic hose fittings out n give the manifold a good clean out.............All the best...hope the above is of some help.....Cheers
  1. water pump hose leaking?
    By vncruzr in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-04-2009, 10:46 PM
  2. water disappearing - water pump - how to change?
    By vh-holden in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-07-2008, 01:30 AM
  3. Davis Craig Electric water pump 80litre pump
    By HIROLLA in forum Parts And Other Items For Sale
    Last Post: 16-07-2008, 10:31 PM
  4. do gen3 have a hose that puts warm water into them?
    By greatone in forum VY Holden Commodore (2002 - 2004)
    Last Post: 26-01-2007, 04:31 PM
  5. Plastic flange or pipe for water hose
    By valet_dave in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-01-2007, 05:44 PM
