Results 1 to 5 of 5
Thread: Battery voltage from the ECU
    aceventura's Avatar
    aceventura is offline Doesn't drive like this
    Mazda 6
    Oct 2008
    SEQ
    Default Battery voltage from the ECU
    I am just trying to understand a discrepancy between the battery voltage I measure with a multimeter, and that read from the ECU.
    While running, the ECU reports a battery voltage of 13.6V and an injector voltage of 14.2V.
    If I use a multimeter to measure the voltage between the battery posts, I get 14.2V. I also get the same result if I measure between the alternator and the negative terminal or the positive terminal and 3 different earth points (on the body near the battery, plus the two earth points on the engine).
    Is this normal? Does anyone know how the ECU determines the voltage? Any comments or suggestions welcome.
    bpefi is offline Tech
    Hilux Ute - Vs Ecotech Engine
    Nov 2009
    Bundaberg
    First you need a high impedance multimeter to use on EFI systems - your usual el cheapo wont be good enough - injector power comes from a different source that the Pcm or ECU - the injectors will have power all the time & it will be grounded by the PCM to make it fire. Should have same voltage with KOEO - with engine running it will use some & the voltage may drop - though I would check back through your electrical system for faults.
    The1's Avatar
    The1 is offline A Memcal a Day Keeps..
    VS V6 Berlina Auto Series 1
    Jan 2005
    Toowoomba QLD
    on VS V6 Battery to Engine Fuse to Red & Black wire B8 & A8 at ecu connectors. Same wire powers the EFI Relay which goes to the injectors, Oil Pressure Switch and DFI Module.
    It depends how the ecu reads the voltage, it may go through a series of circuits before it reads voltage which is causing the slight drop, nothing to worry about with 13.6v
    aceventura's Avatar
    Mazda 6
    Oct 2008
    SEQ
    Thanks guys for the replies. I only know enough about this stuff to know that I don't know much at all.
    Quote Originally Posted by bpefi View Post
    I was only measuring the battery voltage with the multimeter (14.2V), and I don't think I need a high impedance multimeter to do this(?). I noticed that the ECU was giving different readings for the injectors (14.2V) and the battery (13.6V). It just struck me as odd that these two numbers differed, as I a friend has a manual that shows the expected values for these two readings should be the same. On your suggestion I checked the ECU output with KOEO, and the two numbers were: Battery voltage = 11.8V, Injector voltage = 12.2V. So I will do some checking.
    Quote Originally Posted by The1 View Post
    Yeah 13.6V is no problem, the car is running ok. Was just cleaning the earth points in the engine bay and checked all the voltages afterwards. I might check the voltage at the ECU at the connectors you mentioned, might point me in the right direction.
    Is it conceivable that one of the circuits is using an earth point I don't know about (that needs cleaning)???
    The1's Avatar
    Jan 2005
    Toowoomba QLD
    the ecu has an earth point near itself from memory.
  1. Possible to splice a voltage gauge to pre-existing voltage gauge in dash?
    By VLC86 in forum Electrical Wiring / Questions
    Last Post: 16-12-2010, 06:30 PM
  2. Battery Voltage Fluctuates
    By Gunns VC in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 09-05-2010, 11:40 AM
  3. battery voltage issue
    By Dr.304 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-03-2010, 04:29 PM
  4. Error Code #15 and #16 - Coolant temperature sensor high voltage / unstable voltage
    By VSSECO in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-10-2009, 12:15 PM
  5. battery light voltage problem again
    By omaz78 in forum Electrical Wiring / Questions
    Last Post: 09-02-2009, 02:11 AM
