Results 1 to 12 of 12
Thread: Qld Roadworthy Question about Seats.
    vp senator & VS Ute
    Apr 2005
    Default Qld Roadworthy Question about Seats.
    G'day, I recently bought a VS ute and I am getting it ready for Qld Roadworthy Certificate. The ute is fitted with Monza Autotechnia seats will it pass roadworthy with these seats or will I have to fit commodore seats. The seats are good no rips or tears. Thanks for advise on this.
    D22 St-r Navara
    Dec 2010
    perth
    i would say you would have to fit factory seats. as in wa you need a permit to change the seats. as since we are the backward state i would believe the same would be over there
    vp senator & VS Ute
    Apr 2005
    Thanks Krisp, I was thinking along those lines also but I thought a seat company like that may get them approved unlike fitting seats from another car [say Honda Prelude as example]
    regards gaz
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Try ringing Qld transport - they have a 1300 number for modifications (see the phone book for the actual number)...they may be OK if they have passed the Australian Standards test.
    bpefi is offline Tech
    Hilux Ute - Vs Ecotech Engine
    Nov 2009
    Bundaberg
    Any modification to a vehicle needs compliance in Qld - even transmission / diff or motor transplants & being the original fitment for the vehicle - still require a compliance plate - so yes your seats especially would need to be inspected for compliance & a plate issued. If you had a decent accident & someone was hurt your vehicle would be inspected & it would be defected & there would not be any insurance.
    vp senator & VS Ute
    Apr 2005
    Cheers, Thanks for the advise. Think I better start looking for a set from a decent VS, Best regards
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    I'd still contact Qld Transport on 1300658319 - they deal with all roadworthiness items. Most replacement safety related items - uni joints, brake pads/discs, balljoints/tierod ends, bulbs etc fitted aftermarket do not have official compliance so they could also be considered to be reason for a defect notice.
    Nov 2009
    Bundaberg
    I did safety certificates for years in Qld - the rules are still the same & are available on the transport dept website - if you look hard. The replacement of normal wearing parts with parts of a similar type is not a problem - Qld transport wouldn't have a clue mostly unless you manage to speak with someone that looks after that area - which is pretty hard to do. You even have to have an inspection done to remove the mod plate - theoretically.
    Every time over the years when I wanted clarification on the rules no one was available & no one knew what the go was. Its best to speak with whoever you are going to get the safety cert done with as he will have the final say. You will have to contact transport over who can do the mod for the seats if you want to keep them. Good Luck
    VS Calais & vh sl
    Dec 2006
    deception bay
    go see an aprroved inspector and get them mod plated probably cost you $130 and you dont need to change your seats.
    where are you located?
    vp senator & VS Ute
    Apr 2005
    Cheers Blokes and thanks for your advise. You are all pretty well correct. I rang Qld Tport [thanks Hanko for the number] and spoke to a man called Jamie who was very helpful. He said the seats should have a yellow ADR tag attached which they have but I need to get a mod plate from an Approved Person to go through roadworthy. The person signs to say if the mod is done correctly. Also asked about the Clubsport mags on it and he said no problem as long as the track stays within the limits. It has 225 50 16 tires that are stuffed. Think the mags are 8 inch by the looks about the same width as my VP. Thanks again Gaz
    tim005's Avatar
    tim005 is offline Yet Another VS Ute Owner
    99' Series 3 VS S-Pac Ute.
    Feb 2009
    Melbourne.
    Sounds like the usaul mate.
    I wanted to put seats into my VS Ute in Melbourne and was informed that i needed an engineers certificate and all that, kind of turned me off a bit.
    http://forums.justcommodores.com.au/...first-car.html My VS Ute, 99', S Pac, 5 Speed.
    Quote Originally Posted by maldotcom2 View Post
    Also, always go into a corner in second gear in case you see a hot chick or another commodore you can fang it out sideways.
    vp senator & VS Ute
    Apr 2005
    Cheers, I picked up a set of VS equivalent Statesman rag seats yesterday from the wreckers and got 4 new tires so the project is on the way, thanks again for your advise. I was going to buy a headlight there but $60.00 sounded a bit on the high side. Only need to replace the back disc pads and the front pads and maybe the front rotors as they have a bit of a lip. Ordering a set of struts for the toughlid. Regards and all the best for Christmas and New Year. gazza
  1. Urgent please help wiring question for seats
    By 11gothevt11 in forum Electrical Wiring / Questions
    Last Post: 29-08-2010, 10:08 PM
  2. VS Caprice electric seats question
    By shanhsv in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-05-2009, 11:41 AM
  3. Sports seats question
    By Mossman in forum VY Holden Commodore (2002 - 2004)
    Last Post: 30-12-2007, 05:06 PM
  4. seats question
    By slayer in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-11-2007, 02:23 PM
  5. stupid question but how do i remove my rear seats
    By johnvtls1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-09-2007, 12:39 AM
