HELLO ALL...IVE LOST MY RED HSV ISS TAG>> I CAN SOURCE A NEW ISS SYSTEM NEW IN BOX BUT IT IS A SERIES 2, I KNOW A LOT OF PPL AINT GOING TO KNOW TO MUCH ABOUT THIS AS THE ISS IS NOW 14 YO,I CAN GET A NEW SERIES 2 HSV ISS SYST FOR $750, WHAT IM NEEDING TO KNOW IS IF THE SERIES 2 IS THE SAME AS THE SERIES 3 ISS SYSTEM AND THEN IF SO WHAT AND WHO WOULD BE NEEDED TO GET THE NEW ISS SYST INTO MY UTE.....IM REALY NOT WANTING TO GO AND BUY IT FROM EBAY IF IT DOSNT SUIT MY VS SERIES 111 MALOO....ANY HELP ON THIS MATTER WOULD BE OF GREAT HELP....THANKS FOR YOUR TIME, BEST WISHES AND KIND REGARDS TO ALL.MERRY XMAS AND A BETTER UP AND COMMING NEW YEAR
i know this is gonna be a tuff 1 to get an answer on,,,,,but hey some holden nuts gotta know somthing lol..............next best thing ill have to do is ring hsv,and leave my vin on a msg machine and thay will get back to me after thay verify im the owner.............nice 1 hsv
We ALL HAVE 1 THING IN COMMON:THE RELENTLESS PURSUIT OF GRIP
Losing the red tag is unfortunate but it just means that you can't introduce new (black) tags to the ISS system. The system is still fully functional using the black tags.
yes but what will happen when i have to get a new key head? dont i need the red tag to join it to the iss syst....thanks a heap
Yes from what ive been told a vs 2 wont fit into a vs 3 as the pcu is diff
any 1 know were i can get a seies 3 iss syst?
sorry to butt into this thread but are you guys talking about the immobilizer piece that goes under the arm rest.
its an add on to the immobizer , a hsv part. im not sure were it goes but this iss systen is supposed to be an add on to the immobilizer(thats what i can work out from the manul)
cool so if i get a new key and key head it will be ok to use....i must of got misssed up when i red the hsv manual ? i thought it said to intro new keys to the iss you will need the red tag? ill go have a read and try and get my head around my iss prob....i thought i was stuffed when the head and key im using now goes flat? i thought (shit im stuffed if i cant addd the new head to the iss? ill get back to you....thanks for popping in and giving some feedback,,,,cheers
Should i get a key and head cut? And will it work?
You won't have a problem getting a new key head. The ISS system (black/red dongle) and the remote/key are separate from each other (assuming you have the connector in the centre console/arm rest). For models such as the VX (not sure about the VT) the ISS is integrated with the normal key/remote. Note that the key part (metal) can be attached to the new remote, you don't have to get a new key cut (although most places, such as Mister Minute, also cut you a new key).
is the black/red dongle the little plastic thing that you push onto the immobilizer part under the arm rest.(thats where it is on my senator if im thinking of the same thing)
its in the glove box on the ute,,,,i never have to use the black dongy to start the car.in goes the key and she disarms (never had to use the black dony thing at all?
is there a way to disable it. it can get annoying having to out the key in. disable the immobilizer then start the car.
not sure. mines just set like that....no dongy needed to start.do you have the hsv book? it may explain it in there...i dont ever have to use the dongy( not sure why)its arms and resets fine just no dongy neeeded to start the car,cheers
na the car didn't have the manual with it when i got it. i wish it did tho. i was told there is a way to disarm it but im not sure if this is true or not
ill go get my book and have a look,,,
the system is supplied with black tages and 1 red master tag.the red master tag is used ONLY to delete stored codes for lost tags or to introduce new user tags and ignition keys to the system.this is the only way for tags and keys to be introduced to the system and if the red tag is lost the iss system has to be replaced (i thought i read it right in the 1st place) so in other words what i thought wad right( when my battery goes flat on my keyhead in farked)unless i can use the black dongy to disarm the iss ,ive read dr bob can overide the iss.......as for i cant find in the book anything about di arming the iss tag.....
Try the instructions below for disarming the ISS - may not work on VS3.
Service / Valet System Override
To put the immobiliser into system override mode, first ensure that the immobiliser is disarmed and the ignition switched ON. Press and hold the TAG against the recess in the status monitor. After three seconds the LED will start to flash quickly. The LED will continue to flash quickly to warn you that immobiliser is still in override mode. Once system override mode has been entered, the immobiliser will remain in this mode until the TAG is touched against the recess in the status monitor.
thanks a heap
That must be how mines is set up,is it revurse to get it so i havee to use the black dongy to start the car as i wouldnt mind using that way,and 1 more thing? Do i need the red tag to do itthanks a heap for you reply well done
3<<<<< 2 black and 1 only red master tag
you cant get them any more.......i know of a 1 series 2 brand new unopend kit with everything in it that i can get,,,,,but that wont fit into my series 3 from what i know
it said in the hsv man on iss that new key heads must be intoduced with the red tag.....i can still turn the iss off with the black tag,but to introduce new keyheads or black tags i must have the red tag to put the system into learn mode>>>>you may stilll be rite and im reading the book wrong>?? But from what i can gather i need the red tag to intro a new keyhead to the hsv iss....if im wrong( i hope i am ) please let me know...best wishes.thanks for the reply
so how many tags would the car have come from factory. as mine one has the one black tag. can new tags be ordered from hsv
also where were you able to buy a new one from. does hsv still supply new iss kits
The series 2 kit??? A mate of mine has it....(no idea why he aint got a hsv lol) thay are no longer made
is he selling it at all. i might be interested
YES HES SELLING IT......$750,,,i know its a lot,,,but thats what hes asking....if it suited my car i would of alreay brought it lol...and yes its still for sale
cool. i will find out some more info and get back to you on it then
HSV do still have new black tags for sale, I just bought one! They had about 25 left in stock at $60 each. I also bought a spare recepticle $25 (where key touches to arm/disarm) I've just been through the learning process of the iss!!! When i bought my vs s11 senator, it only came with one black iss key (no red master), thought to myself I wouldn't mind a spare just in case, my local hsv dealer told me that they were able to programme black iss key through scan2 tech tool and a phone call to hsv, quoted me $85 to do it, so I booked it in. Guess what? They couldn't do it, they need the red master key!! NO SHIT, this is what i freekin told the guy before I even booked it in, I dont have the red master key!! GRR... So a waste of an hour of my time, but at least there was no charge, LUCKY!! I considered buying that kit off ebay last time it was up for auction, as they are no longer available. However, I was very easily able to get a spare ignition key and 3-button remote programmed without red master key.
i think the guy above is loooking for the full kit *i may be wrong*so???? you can get a keyhead done??? no red tag needed? im sure it said in the hvs manual that a red tag is needed? is your a v2 or v3 and is there a diff? who did the spare ignition key for you and how did you intro it to the car, i never use my black tag i just keep it with my keys,,thanks a bunch..ps were you getting you iss info? from the manual?
