Results 1 to 5 of 5
Thread: Vs maloo,with abs,will big brake upgarde work with abs
    justbad4you's Avatar
    justbad4you is offline IF YOR NOT A HOLDEN
    97 VT BERLINA/ 98 VS SIII MALOO (RED) LX SLR5000
    Sep 2005
    MELBOURNE S/E BAYSIDE
    Default Vs maloo,with abs,will big brake upgarde work with abs
    HELLO ALL IM VERY INTERESTED IN UPGRADING MY VS MALOO BRAKES, CAN ANY ONE GIVE ME AN INSITE INTO WETHER BIG BRAKES WILL AFFECT THE ABS AT ALL, AND ALSO THE CHEAPEST WAY OF GETTING THE KITS( WRECKERS,EBAY,OR ANY OTHER CHEAP PLACE) IM JUST IN NEED OF THE PAARTS AS MY MATE IS A MECHANIC AND WILL FIT THEM OFR ME>>> ANY IDEAS WOULD BE A GREAT HELP. BEST WISHES AND KIND REGARDS TO ALL, HAVE A GEART XMAS AND A BETTER UP AND COMMING NEW YEAR
    We ALL HAVE 1 THING IN COMMON:THE RELENTLESS PURSUIT OF GRIP
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Check the "how-to" section for what you need as this has been covered many times. Every now and then you see 'kits' on Ebay. The larger discs and twin pot caliper will not affect the ABS.
    Sep 2005
    What do you think about getting all vt parts from a wrecker , and does the vs series 3 nrrd the addap plates as well?
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    No problems sourcing the parts from a wrecker - however first you should read the "how-to" which contains everything you need to know about doing this upgrade. It's at: How To - VT Brake Upgrade
    Sep 2005
    Thanks mate i got a kit today,,,,,hoping to fit it over xmax break
  1. Brake Lights Won't Work
    By MikeCuzzy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-09-2010, 09:24 PM
  2. Upgarde Stereo
    By ghazizadeh in forum Car Audio
    Last Post: 03-09-2009, 09:27 AM
  3. vr brake adaptor sleeve for vt brake upgarde
    By picks in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-08-2009, 12:57 AM
  4. all brake lights work but car says otherwise...
    By Darkk_Calais in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-07-2009, 02:49 PM
  5. Glazed rotors Brake work
    By RunninWild in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-10-2008, 01:04 PM
