Results 1 to 6 of 6
Thread: engine bay vac lines (another heater problem)
    Aug 2004
    Default engine bay vac lines (another heater problem)
    Hi guys, i know this has been done to death but ive been searching for 2 days to try and figure this out, we picked up a VR BT1 for my partner for a bargain ($2800!), so as is to be expected there are a few problems, i have fixed most but this damn heater issue is frustrating! i have a max ellery service manual (crap imo), i know there is supposed to be a vacuum tank in the drivers side wheel well, but there isnt one there! car has aftermarket front bar so has probably had a knock in the front at some stage. the heater blows on feet only, and its always warm, or hot, the temp controls allow it to go from hot to hotter. there are 2 vac lines in the engine bay but i have no idea where they are supposed to terminate! the manual is no help and i cannot seem to find diagrams on the net or any threads explaining all of this. pictures are attached to illustrate. i appreciate any help!
    Kind Regards
    Jake.
    vs commodore
    Oct 2009
    Tamworth NSW
    The vacuum reserve tank is under the passenger side front guard,up in behind the front bumper,it looks like a black plastic ball.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Locate the vac ball as Brett says and then trace the line from there...from the look of it both hoses should join at a "T". And welcome to the forum.
    Aug 2004
    So both hoses are supposed to go in to the vac ball? wouldnt the system be vacum control valve -> heater switch and the vent system to the vac ball? as in two different systems?
    vs commodore
    Oct 2009
    Tamworth NSW
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    from TB elbow to one way check valve or filter then tee peice which goes into the dash somewhere round the middle of the firewall and to the vacuam ball then theres another one coming out the firewall to the heater tap
  1. vn heater controls? anybody else had the vacuum lines not work and are they hard to f
    By steveabbott in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-05-2012, 12:39 PM
  2. vp heater vac lines
    By Huntington in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-07-2010, 04:24 PM
  3. vn series 1 engine, new transmission lines?
    By cameron20020 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-03-2009, 02:31 PM
  4. Blocking coolant lines to engine
    By Post Vintage in forum General Discussion
    Last Post: 14-03-2007, 07:46 PM
  5. Heater control vac lines
    By haloeight in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 29-09-2004, 09:56 PM
