Results 1 to 12 of 12
Thread: WTF is wrong with m car help plz
    VR_Acclaim is offline Banned
    Vr acclaim
    Jun 2010
    Default WTF is wrong with m car help plz
    I have a 94 acclaim now all sign point to a cas issue, this is not the case I've tried 2 new ones, it some time rubs perfect the. Itl at up if u put ur foot down to hard, some time even tryin to drive it will also do this, now today i dove it hard and ran fine, what else could be the issue, I've reset the ecu so tommorrow I'll check the codes
    accentstencil's Avatar
    accentstencil is online now Donating Member
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by VR_Acclaim View Post
    You haven't really told us what the problem is.
    MY RIDE
    Vr acclaim
    Jun 2010
    Ok so some time even if u try to drive normally it backfires and stalls but wont restate it just cranks, other times when u put ur foot down it like a car that's low on fuel and just goes dead and returns to idle I've replaced the fuel filter and pump
    VT Commodore
    Dec 2010
    Ipswich
    we had the same problem ages ago.. replace the coil pack and DFI module and the crank angle censer and cam censer and see if that fixes it
    Vr acclaim
    Jun 2010
    RX25SE's Avatar
    RX25SE is offline Real cars are steel cars.
    vsII acclaim wagon
    Jan 2009
    If you have already replaced the CAS, coils and DFI, I would replace the leads when you change the plugs.
    Breaking down under load would normally indicate a secondary (hi voltage) ignition fault.
    VT Commodore
    Dec 2010
    Ipswich
    Quote Originally Posted by RX25SE View Post
    how do u fix that? if someone has that problem?
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by jazmyn88 View Post
    Usually by replacing a faulty spark plug or lead. You can check the resistance of the leads or buy a new set, which is a good idea anyway, especially if they have been on the car for a long time, and the same goes for spark plugs.
    MY RIDE
    RX25SE's Avatar
    vsII acclaim wagon
    Jan 2009
    As above, plus the coil packs.
    92 vp executive v6 auto
    Jan 2010
    deception bay queensland
    maybe crap on the bottom of your tank my wagon does this and thats what ive put it down to
    bottle of metho in the tank
    Vr acclaim
    Jun 2010
    Yeah I stirred it all and didn't really clean when doin the pump due to time n room
    FstStig's Avatar
    FstStig is offline Diagnostician
    1993 VR Calais
    Sep 2008
    Newcastle/Central Coast, NSW
    MAF - Mass Air Flow Meter, TPS - Throttle Position Sensor or your MAP - Manifold Absolute Pressure Sensor. These can sometimes be faulty and cause the above problems.
    If it's not a Symptom its not relevant, and if its not relevant I don't care!
  1. Another Wrong colour fluid in wrong chamber?
    By just_vt_problems in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-08-2010, 07:14 PM
  2. What else can go wrong?
    By s_ikari2015 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-05-2008, 06:33 PM
  3. Is It Wrong? Let Me Know What You Think
    By ASIAN_VP in forum General
    Last Post: 19-03-2007, 01:15 PM
  4. something wrong???? HELP
    By potshots007 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-10-2005, 09:46 PM
  5. What could be wrong?
    By boschee in forum Car Audio
    Last Post: 25-07-2005, 04:43 PM
