Results 1 to 8 of 8
Thread: Vr power steering pump.
    88 VL Turbo SL and 86 VL SL
    May 2010
    VIC
    Default Vr power steering pump.
    Hi i have a problem with my mrs vr wagz when you turn left the pump go loud as all f**k unlike when you turn right. Its leaking power steering fluid aswell.
    Is the whole pump under pressure and is it hard to replace it at home ?
    Modifying a car is like a drug once you start you cannot stop
    Holdens if your not in one your behind one
    D22 St-r Navara
    Dec 2010
    perth
    pump is only under pressure when the car is running, easy to fix yourself
    May 2010
    VIC
    Ok cool thanks.
    Whats the best way to do it.
    The1's Avatar
    The1 is offline A Memcal a Day Keeps..
    VS V6 Berlina Auto Series 1
    Jan 2005
    Toowoomba QLD
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    From the description, it sounds more like a steering rack issue - or if it's been losing a lot of fluid you may have air in the system which you will need to bleed out. The pumps can be overhauled yourself with an "O" ring kit (see how-to). You should find where the fluid is leaking from, otherwise you may be replacing the wrong part.
    RX25SE's Avatar
    RX25SE is offline Real cars are steel cars.
    vsII acclaim wagon
    Jan 2009
    As above, if the fluid level is OK then a noise when turning in one direction only would more likley be a rack fault.
    May 2010
    VIC
    Well its got very low fluid due to a big leak because off a o ring.
    I am just going to replace the whole pump.
    how do you bleed air out.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Put the car up on stands and turn the wheels from lock to lock half a dozen times.
  1. VT Power Steering pump
    By NOSFERATU in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-11-2010, 03:25 PM
  2. Power Steering Pump
    By 05 VZ SS in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-07-2010, 04:24 PM
  3. power steering pump
    By go fast in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-06-2009, 02:07 PM
  4. VS Power Steering Pump
    By kargikai in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-01-2009, 12:30 AM
  5. Replies: 1
    Last Post: 09-11-2008, 09:18 AM
