Results 1 to 6 of 6
Thread: Power steering problem
    VR
    Nov 2010
    traralgon
    Default Power steering problem
    My 3.8 vr has been sitting for just about a year now and I'm finnaly getting her back on the road, I start her and let her run for 10 mins or so most weeks. My powerstearing reservoir is empty and every time I fill it it drains back out, I took the reservoir off and the seals and hose are fine so it's coming out somewhere else. Any one have any ideas where or how I can chek it out? Thanks
    The1's Avatar
    The1 is offline A Memcal a Day Keeps..
    VS V6 Berlina Auto Series 1
    Jan 2005
    Toowoomba QLD
    um steering arm boots probably full of oil then, if that's the case prob easiest fix is replace the power steering rack.
    VR
    Nov 2010
    traralgon
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    All you can do is degrease the area and then inspect. As The1 says, it could be leaking into the boots - try squeezing them and if they are full of fluid you will feel it.
    Also, you say "My powerstearing reservoir is empty and every time I fill it it drains back out,".....can you explain a bit more please.
    VR
    Nov 2010
    traralgon
    What are the boots? I mean I started my car one day and it had no powerstearing fluid, so bought a 600ml bottle or what ever size it was and poured most of it in, then next time I checked my car the powerstearing fluid was empty again.
    vt s pack
    Oct 2010
    brisbane
    keep pouring it in till u c where its coming from.
    fix and replace by then
LinkBacks (?)
  1. VZ SS Power Steering problem
    By loudvtss in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 29-05-2012, 07:28 PM
  2. Power steering problem
    By some_guy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-01-2010, 12:01 AM
  3. power steering problem
    By crazstaat in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-05-2009, 08:32 PM
  4. vs power steering problem
    By alan smithy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-11-2008, 07:41 PM
  5. power steering problem
    By BUSTA in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-08-2006, 10:45 PM
