It's definately NOT advisable to do this while its at running temp but most often will be fine. Your block is made from cast iron which does not like rapid cooling as it shrinks too quickly with cold water so you run the risk of cracking the block.
Z' Series HSV 297KW 6lt LS2 Conversion For Sale!PM Me For Details
As above, use hot water when flushing,
We ALL HAVE 1 THING IN COMMON:THE RELENTLESS PURSUIT OF GRIP
