Results 1 to 9 of 9
Thread: V6 not starting
    VS Berlina soon to be 5L
    Aug 2010
    Girrawheen
    Default V6 not starting
    hi all my beloved vs commodore is not starting, it cranks over but doesnt fire, checked codes none come up, snap on scanner, i've got spark, but dont have clip to get fuel pressure line off at home its at work get it tommorow, but the security coded led goes off when i turn ignition on but starts flashing when i crank it over.
    so is it a bcm issue or a farked fuel pump.( cant here pump priming when iginition turned on)
    whacked the bottom of the fuel tank does nothing
    vs commodore
    Oct 2009
    Tamworth NSW
    If you cant hear the fuel pump prime for the 2 seconds,then thats probably whats wrong with it.You can try to get it running by getting someone to belt the bottom of the fuel tank with a piece of wood whilst you turn the ignition key to the on position.Sometimes its just enough of a jolt to get it running again.
    D22 St-r Navara
    Dec 2010
    perth
    vs commodore
    Oct 2009
    Tamworth NSW
    Usually if its a problem with the ignition keyfob, or if the immobiliser(BCM) doesnt recieve a signal from the keyfob for some reason,the engine wont even attempt to crank over.Try pressing the remote buttons while cranking it and see what happens.
    Aug 2010
    Girrawheen
    GothicKidd's Avatar
    GothicKidd is offline ლ(ಠ益ಠლ
    Series II VR Commodore
    Dec 2010
    South Australia
    Could be a fuse? Check your engine fuse in ur engine bay.. I couldnt start my car, and fuel pump wasnt priming.. and it was just a fuse..
    Aug 2010
    Girrawheen
    VL Commodore
    Dec 2008
    Hi,
    I've got a similar problem i got a VS.
    The car starts, but needs cranking of probably 3 seconds, I don't think I can hear the fuel pump priming,
    but it definitely runs once car is on as it doesn't stall or anything.
    Just wondering how loud should the fuel pump be, do you have to be right near the tank to hear it?
    Aug 2010
    Girrawheen
    what state u in easy as test take the fuel line off at rear of engine bay drivers side turn key onto ignition should have fuel priming out .
  1. Not Starting..
    By snowybill in forum VL Holden Commodore (1986 - 1988)
    Last Post: 12-12-2009, 08:22 AM
  2. Starting
    By YATSIE in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 04-02-2009, 05:59 PM
  3. VN Not starting - HELP
    By ghosty in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-02-2007, 01:27 PM
  4. starting a vn without a key?
    By dave.b in forum Electrical Wiring / Questions
    Last Post: 01-03-2006, 09:06 PM
  5. starting
    By ab56452001 in forum Electrical Wiring / Questions
    Last Post: 04-01-2006, 10:04 PM
