Results 1 to 9 of 9
Thread: How to put lowered coils in front!!!!!!
    VR
    Oct 2010
    woonona
    Default How to put lowered coils in front!!!!!!
    just wondering how to remove the old springs on my VR and put the new ones in..
    i attempted to have a go but the top bolt on the strut in the engine bay just would not come undone
    do i have to undo everything connected to the strut and pull the whole suspention setup out to change the coil?
    pictures would help greatly
    cheers
    Darcon666's Avatar
    Darcon666 is offline Evil is always around you
    The Wife
    Jun 2010
    At home
    Search and ye shall find...
    VS strut removal
    Then you need to clamp/compress the spring, remove the strut top and reverse the entire process.
    Good luck...
    vs commodore
    Oct 2009
    Tamworth NSW
    Just remove the strut from the vehicle,fit spring compressors to the spring and tighten them just enough to take the load off the top nut, and then undo the top nut, and then remove the spring.Spring compressors can be bought cheaply at places like supercheap etc.It can be dangerous to try to remove them without the use of spring compressors. .
    VR
    Oct 2010
    woonona
    VR
    Oct 2010
    woonona
    im having a hard time getting the top nut off, thing wont budge...
    any ideas on how to get it off?
    vx calais superc6
    Sep 2008
    get a big #### off bit of steel piping and slot it over the wrench for extra leverage if everythin else u need to do is done and the nuts stuck, spray it with wd40 too
    1996 VS BT1 SS 5ltr original
    Apr 2008
    a rattle gun will do the trick. i had he same problem with one of mine just took it to bob jane asked them nicely if i could use the rattle gun for a sec and bob's your uncle came off straight away. I have done a few spring changes now and i alway loosen the top bolt just a little before i touch anything and i havent had a drama since. Others may not do the same or think that is right but that is just may little trick.
    VR
    Oct 2010
    woonona
    i just ended pulling off the top rubber and clamping it in the vice and it came straight off.
    justbad4you's Avatar
    justbad4you is offline IF YOR NOT A HOLDEN
    97 VT BERLINA/ 98 VS SIII MALOO (RED) LX SLR5000
    Sep 2005
    MELBOURNE S/E BAYSIDE
    Ask krisp he knows it all???? Or so he thinks
    We ALL HAVE 1 THING IN COMMON:THE RELENTLESS PURSUIT OF GRIP
  1. Independent Rear + Castor/Camber Kit + Lowered Coils
    By vzute2005 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 17-08-2010, 09:57 PM
  2. Lowered VL pedders coils
    By rimz81 in forum Parts And Other Items For Sale
    Last Post: 12-11-2006, 09:43 PM
  3. lowered coils vb-vl
    Last Post: 10-11-2006, 06:49 PM
  4. lowered vb-vl sportsryder coils
    Last Post: 31-12-2005, 04:14 PM
  5. Lowered vl coils(4)
    By rimz81 in forum Swap / Wanted to Buy / Trade
    Last Post: 02-07-2005, 09:30 PM
