Results 1 to 10 of 10
Thread: how to tell the difference between 165kw and 185kw v8 engines?
    vs calais
    Dec 2008
    Default how to tell the difference between 165kw and 185kw v8 engines?
    Just wanting to know how you can tell whether the engine is the 165kw v8, or the 185kw hsv enhanced? besides the engine cover ofcoarse.
    what was actually done to the engines to gain the extra 20kw?
    Reaper's Avatar
    Reaper is offline Tells it like it is.
    E3 Senator Manual, VP SS
    Aug 2004
    Quote Originally Posted by admir87 View Post
    Knock sensor and tune. That is it. The motors themselves are identical.
    Reaper
    Reapers Black VP SS
    0-60 mph = 5.39 Sec, 2.30 60'
    Quote Originally Posted by skruba View Post
    practice makes perfect dude i was (still am) my bros guinea pig,he has been tattooing for near 2 years.
    vs calais
    Dec 2008
    Reaper
    where was the knock sensor put, so i can look for it
    vs calais
    Dec 2008
    and if i cant see the knock sensor, is there a way to tell through the hsv enhanced build plate on the firewall, eg codes/numbers?
    Reaper's Avatar
    Aug 2004
    The knock sensor is located on the side of the block right up under the exhaust manifold/extractors. It can be difficult to see when the motor is in the car.
    Why do you want to know?
    Reaper
    Reapers Black VP SS
    vs calais
    Dec 2008
    looking at buying one, apparently its a 185kw motor,
    does have the hsv enhanced tag on the firewall, but i've heard that it does not specifically mean that the motor was done.
    Reaper's Avatar
    Aug 2004
    pfft - just give it a good service inc coil & leads + give it a tune. Will go faster than any 185kw ever did.
    Reaper
    Reapers Black VP SS
    VS Series11 Ute
    Jan 2005
    Left hand bank behind the oil filter just above the sump and it looks like the pic jb4u posted(eventually ;-)). The wire for it will go past the dipstick tube.
    D22 St-r Navara
    Dec 2010
    perth
    other than the fact i have a vp senator 185kw down the back with a knock sensor
    simmons001's Avatar
    simmons001 is offline I like VS Caprices
    WH Grange/VS Caprice S1 5.0
    Jul 2005
    CAI, extractors, stainless HSV exhaust, HSV chip, knock sensor. That's it from memory.
    I like VS Caprices so much, I bought 2... and a WH Grange!
  1. difference between 07-08 sv6 engines
    By philsv6 in forum VE Holden Commodore (2006 - ?)
    Last Post: 10-05-2010, 11:46 AM
  2. 165kw to 185kw?
    By Skidney in forum V8 Development and Modification
    Last Post: 26-04-2010, 09:07 PM
  3. every 165KW motor isn't a 185KW motor!!!!!!
    By pjdm1980 in forum The Pub
    Last Post: 30-08-2009, 12:52 AM
  4. 185kw engines
    By VPS2 in forum General
    Last Post: 18-04-2009, 07:57 AM
  5. 165kw or 185kw (hsv chip)
    By stumps5L in forum V8 Development and Modification
    Last Post: 10-08-2005, 07:33 PM
