Results 1 to 5 of 5
Thread: Excessive reving when cold
    1995 VS Acclaim
    Dec 2010
    Exclamation Excessive reving when cold
    My 95 VS has started reving excessivley when cold. It only does this when acceleraing as if the clutch is slipping but after a few minutes it starts to get back to normal and runs fine until started from cold again. The problem has seemed to be getting worse over the last few months.
    Can anyone tell me if this is a clutch problem or a choke problem or something else ?
    Thanks,
    Nick
    The1's Avatar
    The1 is offline A Memcal a Day Keeps..
    VS V6 Berlina Auto Series 1
    Jan 2005
    Toowoomba QLD
    VR_Acclaim is offline Banned
    Vr acclaim
    Jun 2010
    Shouldn't be ur clutch as it would slip instead of causing a car to rev out unless it's automn u mean clutch pack which still no really the cause slipping with the bands, now to answer ur question if automthen inwould check ur gearbox oil and see if it's full, also check for thin oil, brow oil indicating fudged clutch packs, or see if anything chuncky is on the Dipstick, also I would be looking at ur torque converter,
    1995 VS Acclaim
    Dec 2010
    Its an Auto .. Not checked the error codes but just read the link and will give it a go .. thanks
    1995 VS Acclaim
    Dec 2010
    Ok thanks .. i'll check the gearbox oil ..
LinkBacks (?)
  1. Excessive oil consumption
    By redlion05 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 26-07-2010, 08:41 PM
  2. vx reving help help?????????????
    By andyvs in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 21-04-2010, 05:20 PM
  3. reving out
    By aza64 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 18-09-2007, 11:29 PM
  4. Excessive fuel use
    By willy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-05-2006, 10:00 PM
  5. Excessive oil use?
    By Scooter79 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-09-2005, 01:50 AM
