Results 1 to 10 of 10
Thread: Will another one work
    VS Commodore Excutive
    Sep 2010
    Cool Will another one work
    Hi All and a merry Xmas.
    My son inlaw has a VR STATESMAN V6 and the speedo shit it self going all over the place and cant find another one so going to get it repaired but going to take awhile. What i want to know will another one fit in until he gets it fixed like a normal vr one just have to have the speedo ,temp and fuel working on it let me know thanks.
    VS S-Pack SII
    May 2008
    ask yourself... how much it cost to repair... compared to buying a replacement one off ebay...
    (ive seen them go for under $100)
    ANY VN-VP cluster is interchangeable...
    ANY VR-VS cluster is interchangeable...
    Regardless of the level...
    BUT.... VN-VP clusters will NOT fit VR-VS ... and vice-versa... different wiring = bang!!!
    All that concerns you is the km's on the ODO... Trying to get a new one that is the same... (or very close)
    Good luck!
    Verynice's Avatar
    Verynice is offline Band
    VS Caprice 5L
    Aug 2008
    SA - The Backwards State
    Just get yourself another cluster, must be a v6 one, then swap over the trip computer blocks, this way you can retain the KMs on the odo
    Sep 2010
    Verynice's Avatar
    VS Caprice 5L
    Aug 2008
    VS S-Pack SII
    May 2008
    Quote Originally Posted by Verynice View Post
    Agreed... and a great idea about the trip cumputer block! *thumbsup*
    Verynice's Avatar
    VS Caprice 5L
    Aug 2008
    also remember to carefully unplug the ribbon cable that is connected to the trip block on the under side/bottom of the cluster before taking the block out
    justbad4you's Avatar
    justbad4you is offline IF YOR NOT A HOLDEN
    97 VT BERLINA/ 98 VS SIII MALOO (RED) LX SLR5000
    Sep 2005
    MELBOURNE S/E BAYSIDE
    the speedo going all over the place if its a level 3 digi dash dosnt mean that its the cluster its self.......if you mean the speedo its self going up then down and all over the place?>then the prob may lay inside the gear box itself>?not a costly fix if its what i may think it could be? ive forgotten what parts needed to go into the g.box to make he speedo act normal>>>>ill get back to you when i remember
    We ALL HAVE 1 THING IN COMMON:THE RELENTLESS PURSUIT OF GRIP
    vr wagon
    Aug 2010
    vic
    Sep 2005
    Speedo cable is binding up and letting go, take it out and lubricate it. may be this,,,chwck all options before you replace the cluster
LinkBacks (?)
  1. Speedo/alert won't work - replaced cluster, still won't work
    By VS Omega in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-05-2011, 10:33 AM
  2. VR 1994 Indicator doesnt work (Hazard lights work)
    By rester in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-09-2010, 01:40 PM
  3. Speedo/alert won't work - replaced cluster, still won't work
    By VS Omega in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-02-2009, 06:54 PM
  4. SWAP: My work for your work!
    By thisispete in forum Swap / Wanted to Buy / Trade
    Last Post: 20-11-2005, 06:55 PM
