Im having problem with my vr v8.. starter wont crank..imobiliser light blink continuously when igition is on.. starter ok when the relay is bridge 30 to 87.. so tried the ignition on for 1 hour. Magic! starts one kick.. I recon the key head is stuffed.. something missing from the head.. to get new key head is not easy here in Brunei. As i have read in this forum need to change the BCM and so on.. Therefore i need to disable the imobiliser.. Whats the simplest way if any, to do it.. I have read somewhere in the forum saying about pink wires on the left of the passenger seat.. Could someone from down under please help me.. Im so anxious to put my v8 o the road again.. Cheers mate..
ham from Brunei
lets just tell everyone on these forums how to steal a vr
i was going to say the same thing,,,,,i was thinking fark off at this time off year was a bit harsh......so hamv8 pls dont ask because i dont think any 1 will tell you.to disable it??? burn the car as it will roll faster as it will be lighter after the fire so you may be able to push it around with your right leg out the door giving you heaps of horse power? ooop i ment leg power....hope this wasnt to rude?cheers
We ALL HAVE 1 THING IN COMMON:THE RELENTLESS PURSUIT OF GRIP
not only that if you got almost 2 ton of car over to the desert id say you wouldnt have a prob gettin a 3 ounce key head up to the desert as well....if you was legit the dealer you got the car off would have records of your purches and im sure for a small fee thay would loook up your details and you vin and if you do own the car its a peice of piss to arrange what ive just mentioned if as you say its only a key thats stuffing up inside and heres a hint if you can get a dealer to sendyou a keyhead? get 3 thay will out live the car................mmm.........mmm.......sounds as shifty as a rat up a drain pipe.....if im wrong god bless you......if any 1 in australia thinks im wrong? in saying what im saying please say so....
You're not the guy that bought the rotors off me a couple of years ago are you?
me? rotors??? last rotors i had was a set of new ones for my vt.from brakes plus in melb.wasnt me
lol cool was he a nice bloke,lol
GOOD TO SEE THAT NO ONE HAS GIVEN ANY ADVICE (re how to steal a car) well DONE
ha ha ha.... thanks mate..apparently no car thiefs are in this forum to share how to.. to me, the tip to switch the ignition for 1 hour and start the car is already a basic way to steal a holden car... i just thought that if i can disable the imobiliser, i will then install a new alarm system, which just cost around 100 bucks which can be found almost everywhere here... you may wish to know that the one and only holden agent in brunei seem to be dying off.. its the hassle of getting the right stuff and professionally install them and make it work again is that really matters... definitely if I was still living in Geelong, I would do as you have suggested..
many thanks again and Wish You Merry Christmas.
Ham
Hey ham,,,,,you got any mates in australia? If so send them your key head and get them to take it to mr minute at any shopping center who then can make as manny coppies as you like then have them send them back to you...........or if you have the head codes tehm self you can send them to a mate who can take the codes to mr minute for you ( i know because last time i had my vt keyhead done the guy gave me my key code and said if i need aother keyhead just bring the code in) thats about the best i can offer your,ps even though your in the desert <holden should still have you vin on record and thay may be able to give you the keyhead code that you can then get some 1 in australia to get a copy of for you.merry xmas to you from australia and j/c have a good new year
Apart from having the car on ignition for 1 hour, there is no other way to start VR's when the key is defective.
Could it just be a battery that needs to be replaced?
cant replace the batteries in the key head or holden at least dont want you too( you can but it takes good eyes and steady hands ) there is a thread some place on cracking the key head open and doing a bodgy battery change......i havnt tried it........has any 1 else changed the keyhead battery?
Merry Christmas to all of u down under.. Thanks for the advice.. yes I still have a few friends there.. will do exactly as suggested. I will pass the VIN and see what he can do.. Many thanks..
Ham
$1 for a battery beats $100 or whatever for a new Key, Holden clearly is trying to make revenue with these retarded key designs.
you could get a wiring diagram of the bcm follow the sercurity wires either connect them or find a way to short them out . justbad4you seriously man what the fu*k is with your replies? i know i have problems but hell
best of luck ham. and ps mate when you do get a new head ( get 2 or 3 ) that way you wont get stuck for at least a few years to come, have a good new year
Z2tt>>> do you know or have you done a battery change before( if so how hard was it) ive got an old key head id like to give it a try on,,,,thanks in advance,,,,cheeers
