Results 1 to 10 of 10
Thread: VS3 V6 UTE - Front Disc Rotors
    VS3 Commodore Ute
    Dec 2008
    Default VS3 V6 UTE - Front Disc Rotors
    Hey
    I just rang lube mobile to enquire how much to supply and install 2 new disc brake rotors for the front, and they say that the fronts are larger than the rear. Is this a load of crap or is right? As the price for the job is way more than what they previously charged me when they did my rears.
    I just know from previous experience its not always good to accept what they tell you, especially when previously when I did the rears it was only until I called back did I get a good price (ie saying I could get it done cheaper with a competitior).
    Anyway just thought I'd ask to see how true this is to make sure they aren't making up crap to rip me off.
    The exact model of the car is 1999 Holden Commodore VS3 UTE.
    Thanks
    Darcon666's Avatar
    Darcon666 is offline Evil is always around you
    The Wife
    Jun 2010
    At home
    Yes they are larger but are easier than the rear... took me 5hrs on a weekend to do mine with plenty of beerstops in between. So by my reckoning it should only take a couple of hours for an experienced mechanic
    1). WD40 the Callipers & the front/Rear of the rotors
    2). Undo the calliper and hang it up with some wire on the spring.
    3). With a Rubber mallet, tap the rotor and it will come off(If it doesn’t use more WD40, have a couple of beers and give it an hour...) try again.
    4). Push back the pistons in the callipers(take note of the Brake fluid as it could overflow)...
    5). Optional but I would recommend is to use new pads.
    6). Reverse the process.
    P.S Use Lock tight on the calliper bolts... when putting them back in.
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    An experienced mechanic should take about 30-45 minutes to do front rotors on a VS.
    I can supply slotted front rotors for $165 a set.
    Visit my Facebook page
    VS3 Commodore Ute
    Dec 2008
    Ok I got another quote from another mobile mechanic, and they quoted significantly less than Lube mobile. So I'm going with them. Basically Lubemobile wanted $412 and this other mobile mechanic is able to do it for $323. I got my rears done (new rotors and pads) for $292 in Oct, so being that the fronts are indeed larger I'm willing to be a a bit more but not like $412 more .
    Thanks for the replies guys.
    Darcon666's Avatar
    The Wife
    Jun 2010
    At home
    Quote Originally Posted by pengoau View Post
    Just curious.... Does this include rotors/front discs as well and how long/No# of hrs did they say it would take????
    VS3 Commodore Ute
    Dec 2008
    yes supply and installed. parts and labor.
    Lubemobile could only come down to 389.
    Darcon666's Avatar
    The Wife
    Jun 2010
    At home
    Cool, that's an OK price.... anal-Lubemobile tends to overprice on the labour a bit too much for me.
    RX25SE's Avatar
    RX25SE is offline Real cars are steel cars.
    vsII acclaim wagon
    Jan 2009
    Quote Originally Posted by Darcon666 View Post
    New pads should always be fitted to new rotors so they bed in correctly.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Actually the rear rotors are more expensive that the front for 2 reasons - first is that they have a brake drum formed as part of the rotor for the handbrake so the actual disc costs more, and second, the labour cost in changing the rear rotor is much greater than the front rotor as the handbrake shoes need to be removed/reinstalled/adjusted.
    VS3 Commodore Ute
    Dec 2008
    Thats not what I've found, my front brakes cost more to do than the rears.
    Fronts - 323
    Rears - 292
    Brake service = new rotors, new pads supplied and installed.
  1. VX new front disc rotors, where to get & how cheap?
    By Fuzzypumper in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-01-2010, 11:14 AM
  2. [SA] VN V6 Front Disc Rotors
    By Vr929 in forum Swap / Wanted to Buy / Trade
    Last Post: 21-07-2009, 06:10 PM
  3. [SA] WTB - old 2nd hand disc rotors (front VT-VZ)
    By Drew in forum Swap / Wanted to Buy / Trade
    Last Post: 19-02-2009, 01:09 PM
  4. Swap VY front disc rotors for VT ss wheels
    By r2e2 in forum Swap / Wanted to Buy / Trade
    Last Post: 27-08-2008, 08:06 AM
  5. disc rotors
    By ab56452001 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-06-2008, 02:26 PM
