Results 1 to 20 of 20
Thread: Vs caprice wheel bearings
    turmoil117's Avatar
    turmoil117 is offline Donating Member
    vn berlina, vr statesman
    Jan 2010
    Westminster
    Default Vs caprice wheel bearings
    I'm buying a series 2 vs caprice just after Christmas and it has noisy front wheel bearings. I was hoping someone on here would be able to tell me how hard they are to change and how. Any help would be appreciated
    Darcon666's Avatar
    Darcon666 is offline Evil is always around you
    The Wife
    Jun 2010
    At home
    They are not that hard to change...
    1-2hrs to remove the callipars, front discs/rotors.
    Then the bearing can come out by undoing the rear botls.
    Problem is if the knuckle/stub axel is also rooted then your problem became alot more complicated.... lol
    turmoil117's Avatar
    Jan 2010
    Westminster
    vs commodore
    Oct 2009
    Tamworth NSW
    The front wheel bearings and hub assembly on the VS are a sealed unit and the hub assembly has to be replaced as a complete unit if the wheel bearings are worn or noisy.I replaced mine not too long ago and I got prices ranging from $200 to $500 each side.I ended up getting genuine original ones from a holden dealer for $190 each side.There are different hubs too,depending on if the vehicle has ABS or not.Im pretty sure the ABS hubs are more expensive than the non ABS hubs.Id just call around a few different places including a few different holden dealers before buying them,also there are some cheap chinese made hubs around ,Ive seen them on ebay before,they are a lot cheaper than the genuine ones,but Id stay away from them,apparently they are bodgey and people have had problems with them..
    RX25SE's Avatar
    RX25SE is offline Real cars are steel cars.
    vsII acclaim wagon
    Jan 2009
    Quote Originally Posted by Brett_jjj View Post
    FYI.
    There are also two types of VS ABS front hubs. ABS with 5 link rear suspension (solid axle) and ABS with IRS.
    They are not interchangeable as each has a different tooth count.
    vs commodore
    Oct 2009
    Tamworth NSW
    Im pretty sure the right and left ABS hubs are not interchangeable either,unlike the non ABS hubs where you can use the same hub on either side..
    turmoil117's Avatar
    Jan 2010
    Westminster
    Oh wow now it's complicated. Does anyone know which ones I'll need for the caprice?
    Darcon666's Avatar
    The Wife
    Jun 2010
    At home
    Quote Originally Posted by RX25SE View Post
    FYI.
    Sorry, but unless I am missing something.... (I'm no mechanic... lol)
    What does the rear suspension have to do with the OP about the "Front Wheel Bearings"????
    turmoil117's Avatar
    Jan 2010
    Westminster
    Darcon666's Avatar
    The Wife
    Jun 2010
    At home
    Quote Originally Posted by turmoil117 View Post
    Sooo I'm still only up for new bearings then?
    Yes... but the price diff between ABS and non ABS is half/double. So ABS=$200-290 / Non ABS= $90-180 depending were you get them from.
    E.g. These turkeys are a little expensive(quick 30sec google...)
    Holden Commodore VR - VS Front Wheel Bearing Hubs NoABS
    Holden Commodore VR - VS ABS Front Wheel Bearings Hubs
    A little better for non ABS....
    http://www.commodoreparts.com.au/hol...nabs-3948.html
    http://www.commodoreparts.com.au/hol...-hubs-692.html
    vs commodore
    Oct 2009
    Tamworth NSW
    Quote Originally Posted by Darcon666 View Post
    The abs sensor pulse rings have a different number of teeth, depending on whether the vehicle has a solid rear axle,or IRS.
    Darcon666's Avatar
    The Wife
    Jun 2010
    At home
    FFS.... But the OP is not talking about the rear, we are talking about the FRONT.... is this me or are some people in this thread just plain missing this????
    turmoil117's Avatar
    Jan 2010
    Westminster
    vs commodore
    Oct 2009
    Tamworth NSW
    The front ABS hubs are different depending on if the car is IRS or non IRS.I cant see why you are saying it has nothing to do with the front,it has everything to do with the front.If you get new front hubs, and they are for a solid axle vehicle,then they will be the wrong part if you have an IRS equipped vehicle and vice versa..
  15. #15
    vs commodore
    Oct 2009
    Tamworth NSW
    Mate does your car have ABS?
  16. #16
    turmoil117's Avatar
    Jan 2010
    Westminster
  17. #17
    Darcon666's Avatar
    The Wife
    Jun 2010
    At home
    LOL.... Well we are talking about a VS caprice anyway.... so as far as I know they only had IRS rear end and ABS as standard.
    VS Caprice Specs
  18. #18
    vs commodore
    Oct 2009
    Tamworth NSW
    You will need to know if the car has ABS and IRS,and just let the spare parts guy know if it has or it hasnt.It might have ABS with the IRS,or maybe its got neither,or it could even have just one of them.Im not sure what the caprice's specs were,but Id say they would have both though being a luxury car.Just check it out when you get it and go from there.
  19. #19
    RX25SE's Avatar
    vsII acclaim wagon
    Jan 2009
    The tooth count for the REAR axle is different depending if it's IRS or solid axle. The tooth count FRONT and REAR must be the SAME.
    Geddit?
  20. #20
    Darcon666's Avatar
    The Wife
    Jun 2010
    At home
    Gotit... Didn't know, nor did I say I did..."I'm no Mechanic... lol"
    Anyways it's a VS Caprice so IRS & ABS were standard.
  1. wheel bearings
    By frogs in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-05-2009, 02:36 PM
  2. VS Wheel Bearings & Axle Bearings
    By Harvs82 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-09-2006, 07:41 PM
  3. wheel bearings
    By ab56452001 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-01-2006, 12:13 PM
  4. VP Wheel Bearings.
    By RAMJET in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-07-2005, 03:18 PM
  5. wheel bearings
    By sully in forum VL Holden Commodore (1986 - 1988)
    Last Post: 13-05-2005, 07:09 PM
