Results 1 to 9 of 9
Thread: VS Ute Speedo Question
    2003 VY SS Ute M6 2005 WRX STI
    Nov 2010
    Default VS Ute Speedo Question
    Hi Folks, recently I have removed my speedo to replace the small cog which breaks and stops the ks clicking up on it, i cant seem to remove the lead which is connected to the speedo cluster by a small plastic plug (virtually the last thing before its all apart) and wondering if there is a trick to it? I feel like I will break it if I put anymore force on it, also after refitting the speedo needle has dropped down all the way to hitting on the housing of the speedo, the needle works but is abour 20km out now as it drops down past the resting point, can you fix this? should I just buy a new speedo cluster? what are they worth to buy, mine has the tacho so im hoping to get another the same if possible? cheers
    D22 St-r Navara
    Dec 2010
    perth
    use a small flathead to lever the plug off and the speedo needle can be moved all the way in a clock wise direction till you feel resistance. then let it go and keep doing it till it rests on zero
    Nov 2010
    thanks mate its fixed, how hard is the cog to remove from the speedo cluster once its out, looks complicated, cheers again!
    D22 St-r Navara
    Dec 2010
    perth
    depends on how hard you want to make it, from memory just unscrew the side plates with a small phillips and be gentle as hell when pulling it apart. take photos of it before stripping it down so it can assist in puttin git back together
    vs commodore
    Oct 2009
    Tamworth NSW
    Check out the how to in this link.I just fixed mine the other week,it works perfect again now ,I though it would have been a lot harder to fix than it actually was..
    ---Broken Odometer---
    justbad4you's Avatar
    justbad4you is offline IF YOR NOT A HOLDEN
    97 VT BERLINA/ 98 VS SIII MALOO (RED) LX SLR5000
    Sep 2005
    MELBOURNE S/E BAYSIDE
    hey bret not that i need to do mine,but how long did it take you to do it mate
    Quote Originally Posted by Brett_jjj View Post
    We ALL HAVE 1 THING IN COMMON:THE RELENTLESS PURSUIT OF GRIP
    D22 St-r Navara
    Dec 2010
    perth
    Quote Originally Posted by justbad4you View Post
    depending on your abilities anywhere from 30 minutes to 2 hours
    vs commodore
    Oct 2009
    Tamworth NSW
    It took me around an hour or so to replace.I cleaned all of the dust out of it while it was apart,so it probably took a bit longer than it usually would.
    Sep 2005
    Me and small plastic items dont get along to well lol so im my case 2 clusters ( a new 1 after i smash the 1 i was trying to fix in the 1st place) and hours of waisted time better spent under the bonnet with steel nuts & bolts lol
    Quote Originally Posted by krisp View Post
    cheers mate alls good
  1. Speedo Needle - Weird Question
    By VXHBD6 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-12-2009, 02:55 PM
  2. Random question regarding 250kmp/h speedo
    By shanhsv in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-11-2008, 04:51 PM
  3. speedo question
    By Bubbles in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-10-2007, 06:33 PM
  4. speedo question
    Last Post: 28-08-2006, 06:56 PM
  5. Question Regarding Manual Conversion Speedo wiring
    By Dub Alley in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-07-2006, 07:39 PM
