Results 1 to 7 of 7
Thread: automaticly unlcoks after locking with remote (vr)
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    Default automaticly unlcoks after locking with remote (vr)
    hey parants vr wagon 1993, wen u lock it with key (2 different keys) it atomaticly unlocks straight away
    wat would cause this? you can however lock it manually and it will stay locked but yeh with key just unlocks itself automaticly straight away
    im thinking bcm? hope not
    all locks seem free so i dont think its sticking
    cheers
    D22 St-r Navara
    Dec 2010
    perth
    might be the cable that connects to the underside of the door handle has jammed or the central locking motor is dicki on the drivers door
    justbad4you's Avatar
    justbad4you is offline IF YOR NOT A HOLDEN
    97 VT BERLINA/ 98 VS SIII MALOO (RED) LX SLR5000
    Sep 2005
    MELBOURNE S/E BAYSIDE
    It may be the inners of a keyhead playing Up ??
    Quote Originally Posted by jas98 View Post
    wat would cause this? You can however lock it manually and it will stay locked but yeh with key just unlocks itself automaticly straight away
    im thinking bcm? Hope not
    cheers
    it may only be the 1 key playing up,,,,take 1 key to were it wont to anything,then test each key away from the other as it may be the same key relocking because its next to the one your testing.if both keys when tested are the same its not a keyhead.....just a starting point good luck
    We ALL HAVE 1 THING IN COMMON:THE RELENTLESS PURSUIT OF GRIP
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    Quote Originally Posted by Krisp View Post
    cheers with check that
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    Quote Originally Posted by justbad4you View Post
    it may only be the 1 key playing up,,,,take 1 key to were it wont to anything,then test each key away from the other as it may be the same key relocking because its next to the one your testing.if both keys when test are the same its not a keyhead.....just a starting point good luck
    im dumb didnt even think of that, will try that thanks
    Sep 2005
    No worries champ your gotta start at some place.so start cheap and blame the keys 1st lol do that test and either eliminate them or blame them llol,,,,either way best of luck with the car and in 2011
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    It sounds like one of the lock actuators has failed, and is not fully locking - this will make the doors unlock. I would wind all windows down (to allow access to the snipper button), then shut all doors. Press the lock button and watch the movement of each snipper as it is drawn down by the actuator....look for one that is either sluggish or doesn't travel as far - this one could be the offender. I'd also try (with car unlocked) pressing down each snipper in turn manually which should make the other 3 lock. (not sure if this happens in VR but does on my VS)
    Good Luck.
  1. Locking Automaticly when sutting drivers door
    By [Linkin Park] in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 27-06-2009, 04:20 PM
  2. Remote Central Locking
    By VN_Luke in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-02-2006, 03:27 PM
  3. Remote Locking,
    By patullose in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-10-2005, 09:21 AM
  4. remote locking/alarm
    By toolbox1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-07-2005, 01:35 PM
  5. Remote locking
    By VN Shane in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-08-2004, 09:33 PM
