Results 1 to 5 of 5
Thread: vr battery relocation
    VL Calais Turbo, DVS.42L Vr
    Aug 2008
    Nowra
    Default vr battery relocation
    Hey i was wondering if it was hard to relocate the battery to my boot. And what size wire do i need to use
    Aug 2008
    Nowra
    Also does this have to get engineered and put in a sealed but breathable battery box
    justbad4you's Avatar
    justbad4you is offline IF YOR NOT A HOLDEN
    97 VT BERLINA/ 98 VS SIII MALOO (RED) LX SLR5000
    Sep 2005
    MELBOURNE S/E BAYSIDE
    Just move the battery. You will need bigger cable because of the increased length. Also you could connect the battery earth to a convenient spot in the boot area. The +ve will have to be fixed under the floor pan running back to the engine bay. Steer clear of the fuel lines and run it inside a conduit. Do not run the +ve inside of the cabin because if there is a short etc. the cabin will fill with smoke and carpet/plastic will catch fire immediately.
    Thats all i can think of now.
    We ALL HAVE 1 THING IN COMMON:THE RELENTLESS PURSUIT OF GRIP
    Aug 2008
    Nowra
    MR.HG's Avatar
    MR.HG is offline makin teh mods QQ
    VSIIBerlina, HG Brougham
    Dec 2010
    just a normal battery box will be fine so long as it is secured to the vehicle and i would run an earth to the block for sure. i had a switch in my vk once that controlled the electric fuel pump, saved the car from theft once(car started up fine and got out the driveway, 1st....2nd....died, walked outside and up the road to where my car was but they ran straight away) which was good but eventually shorted out and set the carpet on fire. Out of curiosity...why would you want to move your battery to your boot for? it was common in pr-emissions control vehicles since it was easier to clear the engine bay. so much shit in these engine bays man, and all needed for roadworthiness
    Growing old is inevitable, Growing up is optional.
    View my - 97 VS Berlina series2 http://forums.justcommodores.com.au/...ml#post1738670
    - 70 HG Brougham Project http://forums.justcommodores.com.au/...-brougham.html
  1. Battery relocation
    By 05 Senator in forum VL Holden Commodore (1986 - 1988)
    Last Post: 15-06-2010, 12:25 AM
  2. IAT Relocation
    By wadevzss in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 15-12-2009, 06:59 PM
  3. 304 alternator relocation
    By v8_bomberdore in forum V8 Development and Modification
    Last Post: 24-07-2009, 09:19 PM
  4. MAF Relocation
    By Slippy_Trippy in forum V6 Development And Modification
    Last Post: 15-06-2009, 04:03 PM
  5. T/b relocation
    By 10000_fists in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-02-2008, 08:18 AM
