Results 1 to 12 of 12
Thread: please help!!!95 vr s2 motor change for vn s2 vr has cam sensor... is there a way?
    vr wagon
    Aug 2010
    vic
    Default please help!!!95 vr s2 motor change for vn s2 vr has cam sensor... is there a way?
    hi there, i recently blew my engine in my car 95 vr s2 i took a mechanic to lookj at some cars he picked a 91 vn s2 both motors have been taken out and puting the vn motor in iv descovered it doesnt have a cam sensor.... what can i do now? any ideas? do you know if the timing cover off the vr will work on the vn? i blew the cam bearing in the vr motor could i just swap it with the vn? please help...
    ve ssv/vr calais V6 turbo oneday N/A Track car
    May 2010
    Rockhampton QLD
    You should be able to swap the timing cover and there is a pick up in the cam gear
    I did an engine swap and had the same thing i just tied the sensor out the the way and didnt use it and had no problems.
    vr wagon
    Aug 2010
    vic
    i have a backyard mechanic doing the swap over he said it would play up with the transmittion and ecu if we did that...
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    According the the Gregory manual, the cam position sensor information along with other sensor input is used by the ECU to tell the DFI when to fire the plugs - if it's missing it will use a default value "allowing near normal operation". It should not affect the transmission or damage the ECU.
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    I know it's a bit dodgy but I just used a one of those hole cutters on a drill and then swapped over the magnet on the cam gear from the old motor to the new motor as the cam gear already has the place for the magnet anyway!
    You can get the position buy bolting the cam sensor on to the new motor and spray some black paint over it then remove the sensor and you've got a marked to drill through. I think it was a 27mm I'll have a look later.
    vr wagon
    Aug 2010
    vic
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    Might get a few in there but it only alloy, just do it slowly and keep cleaning the swarf off. Did mine last year and she still going fine.
    justbad4you's Avatar
    justbad4you is offline IF YOR NOT A HOLDEN
    97 VT BERLINA/ 98 VS SIII MALOO (RED) LX SLR5000
    Sep 2005
    MELBOURNE S/E BAYSIDE
    Ask krisp mate there aint a lot he dont know........or so he thinks
    We ALL HAVE 1 THING IN COMMON:THE RELENTLESS PURSUIT OF GRIP
    MR.HG's Avatar
    MR.HG is offline makin teh mods QQ
    VSIIBerlina, HG Brougham
    Dec 2010
    justbadforyou why dont you go all kung fu panda on krispy cremes ass? ask him for his address and go bash him in the face tough guy or shut you face its really getting old.
    Growing old is inevitable, Growing up is optional.
    View my - 97 VS Berlina series2 http://forums.justcommodores.com.au/...ml#post1738670
    - 70 HG Brougham Project http://forums.justcommodores.com.au/...-brougham.html
    Sep 2005
    Ask krisp he knows it all???? Or so he thinks
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Quote Originally Posted by pjdm1980 View Post
    That is a great method....much easier than swapping the covers. I like it.
    vr wagon
    Aug 2010
    vic
    how hard are the covers to change any ways? i got both motors out just sitting here, im guessing new gaskets and a half a day right? or should i try drill and might stuff it?
  1. change cam sensor
    By 94calais in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 21-12-2010, 02:34 PM
  2. how to change co2 sensor
    By patullose in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-01-2010, 01:43 PM
  3. Alloytec Oxy sensor change - HELP!
    By Danoz in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 03-11-2009, 07:50 PM
  4. [VR-VS] Change a Coolant temp sensor (V8)
    By undar8ed1 in forum Holden Commodore How-To's
    Last Post: 22-05-2009, 08:09 PM
  5. how 2 change crank angle sensor ?
    By muzza in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-10-2008, 06:21 PM
